Help wanted:  motor stuck when powered
Old 14th May 2019, 11:43 PM   #11
Galu is offline Galu  Scotland
"Firstly is a run capacitor, not a motor start capacitor."
Yes Mark, there is no switchable starting capacitor in parallel with a run capacitor with this motor.
Suffice it to say that this motor has a single capacitor which is permanently connected in series with the auxiliary winding (also called the starting winding).
Strangely enough though, it's called a 'motor start capacitor' in the turntable manual!
Old 15th May 2019, 10:24 AM   #12
ralphfcooke is offline ralphfcooke  United Kingdom
If you rotate the motor spindle when power is applied, using as much force as necessary, does the effort feel like a mechanical problem, or is there only a magnetic resistance?
Old 15th May 2019, 11:13 AM   #13
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
An important give-away is that before dis-assembly, all worked well. So it's unlikely that any of the parts all of a sudden have died at just this instance.
It heavily smells like an assembly error. I understand that your feeling is that you assembled it perfectly, that is a normal reaction.
Yet the evidence indicates otherwise.
Try to retrace your steps. Did you make pictures before-after?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 15th May 2019, 11:24 AM   #14
K.A.B is offline K.A.B  Sweden
K.A.B's Avatar
Have you measure the stators are the caps new or old, old can alter to bad when power switch on.
When i restored an TD124 to a friend it was newer used broken they sayed what i was found vas one wire how was bad connected too the wiring loom check it again.
Old 15th May 2019, 12:38 PM   #15
banpuku is offline banpuku  United States
Here is an update:
1. I measured capacitance using the voltmeter. Both caps measured to spec: 1uF and 2uF. So, the caps are good.
2. Here are the measurements of the motor terminals. 2 sets of measurments. Using the continuity function on the VOM, here are the results:
black - blue: UL (unlimited)
black - orange/green: UL (unlimited)
blue - orange/green: 227 ohms
Then, measuring the resistance using the VOM:
black - blue: 665 ohms
black - orange/green: 427 ohms
Not sure if this helps. Thoughts?
Pat
Old 15th May 2019, 12:43 PM   #16
Further update:
1. I will retrace my assembly steps this afternoon and see if it helps. Certainly could be my issue when re-assembling.
2. The caps appear to be the original caps. Old. that said, they did measure to spec 1uF and 2uF.
3.If I rotate the motor spindle when power is applied, using as much force as necessary, it feels like a magnetic resistance keeping the motor stationary. It prevents me from turning the motor in either direction. I can feel the vibrating magnetic field. I do not get the sense that it is a mechanical interference issue.
Old 15th May 2019, 03:27 PM   #17
From your resistance readings:
227Ω is the auxiliary winding (capacitor goes in series with this winding)
427Ω is the main winding (the supply voltage goes across this winding)
665Ω is the sum of the two windings
These readings look OK so the windings are intact. The fault would appear to lie with your rewiring provided, as you say, the capacitor is fine.
Old 15th May 2019, 03:42 PM   #18
When checking your wiring to the coloured motor wires, make sure that:
Line voltage is applied across black and green/orange
Capacitor is connected across black and blue
Old 15th May 2019, 03:51 PM   #19
HOLD that last post! That doesn't seem to correspond to your wiring digram. I'm rechecking!
Old 15th May 2019, 04:00 PM   #20
Got it the wrong way round! 427Ω is the auxiliary winding and 227Ω is the main winding!
Line should be across blue and green/orange
Capacitor should be across black and blue as stated earlier
Help wanted:  motor stuck when poweredHide this!Advertise here!
WANTED Roksan Radius 5.2 Motor or Motor Spindle kornhead Swap Meet 0 6th October 2018 11:36 AM
Compact Disc Motor and Turntable - Advices for Replace and Motor Service wanted tiefbassuebertr Digital Source 8 21st September 2018 04:39 PM
Single Phase Power Source (AC Regenerator) for Induction Motor Powered Turntables kevinkr Analogue Source 68 17th September 2015 08:43 AM
WANTED: Thorens TD 160 motor!!! javisaxonjr Analogue Source 9 10th December 2014 08:27 AM
Turntable motor wanted lassipr Parts 1 24th March 2010 09:16 PM
Copyright ©1999-2019 diyAudio
