So you think you want to play with tape: An Otari Story
Old 14th August 2019, 12:17 AM   #231
kevinkr's Avatar
Interestingly there are 11 pairs of 0.1uF bypass caps with a pair right near these op-amps. (I may add some more)
Scope shows no evidence of oscillation - I may need to dig out the 100MHz analog scope.
I did not look at the turn off behavior so I will need to revisit it. There may be a relatively simple fix or I may simply not care.
The biggest benefit comes from installing in the first stage which is muted. There was an incremental improvement in playback with the additional op-amps.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th August 2019, 09:05 AM   #232
dotneck335 is offline dotneck335  United States
Hmmmm.... Rod Elliott also found this strange phenomena with TL072 chips in his crossover project, and put in a mute circuit to avoid it.......He said 4558s did NOT do this, but I'd hate to use those for anything!
Old 16th August 2019, 02:52 AM   #233
kevinkr's Avatar
These replaced 4560s. The other machine with stock op-amps does not do this and I am 99.99% sure this one didn't before I changed the op-amps.
The day I forget to mute the pre-amp could be the day that I fry my bass amps and woofers so I will either need to fix this eventually or undo this mod - a shame because it's definitely an audible improvement.
I will not be changing out any more in this machine since modern high voltage op-amps appear to be unsuitable for audio use unless you use a mute circuit.
I will verify that the supplies collapse in a symmetrical manner, other than that there isn't much I can do unless I add a muting circuit.
Old 17th August 2019, 03:02 AM   #234
anatech is offline anatech  Canada
anatech's Avatar
Hi Kevin,
Use a shorting relay to mute. That won't affect the sound quality.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 17th August 2019, 07:24 AM   #235
Man, that's a shame! Surely one of the geniuses here on the forum can come up with a solution. Bleeder resistors across the power supply caps? Lower the +/- V and use 4562s? Someone MUST have come across this before.
Old 17th August 2019, 09:30 PM   #236
kevinkr's Avatar
I can think of several solutions and may try a few when I have a bit more time.
The LME49860 is reputedly nothing more than the high voltage version of the LM4562 so I suspect swapping it in with a lower PSU voltage probably isn't going to fix it.
Old 18th August 2019, 10:25 AM   #237
Good point; but I have dozens of 4562s in my gear and have never encountered the problem you are describing. Hmmmm.... wonder if it is somehow power-supply related? Maybe you could shoe-horn in one of LV's NoNoiser circuits? D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based V.Reg.
Old 18th August 2019, 02:45 PM   #238
kevinkr's Avatar
It's definitely something I need to measure, the schematics indicate that the supplies are symmetrical or should be depending on the loading.
Old Yesterday, 02:01 AM   #239
kevinkr's Avatar
It's pretty much the op-amps.. LOL I installed some more tonight, and it got even worse. I will likely add muting relays at the output at some point.
Apparently the better op-amps are audible, although given the whole record and playback process I sort of wonder why. I figured the process was so flawed that replacing a device orders of magnitude closer to mathematical perfection would be inaudible due to the gross errors elsewhere, this doesn't seem to be the case. I will admit I have made a lot of changes to this machine that contribute to the improved performance so at some point I need to measure a few things and see how good this machine is against the original performance claims.
I should probably take some more pictures of this machine, it looks a whole lot less shabby than when I got it. (Still some obvious signs of wear and tear but a lot of things have been replaced..
So you think you want to play with tape: An Otari StoryHide this!Advertise here!
Otari MX7000 Megaphon Analog Line Level 4 19th February 2019 04:45 AM
use of a tape recorder's play-head as a mic. dehmat Analogue Source 9 5th October 2016 03:11 PM
Otari MTR-15 tape alignment kamran Analogue Source 8 27th September 2011 03:18 PM
Otari MTR-10 Voltages marklang Analogue Source 14 9th April 2011 08:09 PM
How play tape through a computer CarlU Digital Source 1 27th August 2006 11:42 AM
Copyright ©1999-2019 diyAudio
