Humming noise coming from TT
Old 17th April 2019, 07:14 AM   #1
Ben Culley is offline Ben Culley  Australia
Default Humming noise coming from TT
Hi All,
I have recently finished building a turntable with a linear tracking tonearm.
I have set up everything and I noticed a humming sound through my speakers when I set down the needle onto the vinyl.
I have realised that it is caused by the Aquarium air pump. When I turn off the pump there is no noise. I have tried plugging there pump into a different socket on the other side of the room via an extension lead but I am still getting the humming sound when it is conected.
Can anyone help me with this? Do I need to get some sort of filter to stop the humming noise?
Thanks in advance
Ben
Old 17th April 2019, 11:22 AM   #2
indianajo is offline indianajo  United States
indianajo's Avatar
I suggest you take the air pump out of the turntable and put it somewhere else. Air can be moved around in flexible hoses. A tank can act as a local accumulator. Motors and transformers can emit magnetic flux at the line frequency.
Amp builders spend a lot of money to encapsulate transformers in steel cases and behind additional steel walls from the high gain circuitry. A magnetic phono cartridge and the wires from it end directly in a high gain point.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 17th April 2019, 12:15 PM   #3
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Surely the magnetic vibration (Magnetostriction) of the core of the pump's iron core is transmitted via the TT to the disk and reproduced by the capsule. Increase vibration isolation or more over, change one of them away the other.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 18th April 2019, 06:10 AM   #4
Thanks very much for your replies.
I have solved the problem. The pulsating air from the pump was causing vibration in the air chamber. The stylus was picking this up.
I have connected the air via a ‘Smoothing tank’ and now there is no humming!
Cheers
File Type: jpg D84ED432-3C6C-4F4C-8A78-415FB359FDDB.jpg (618.8 KB, 54 views)
Old 27th April 2019, 10:22 AM   #5
Audiofirst is offline Audiofirst  Australia
Cheers
That's a serious turntable you have there, Ben!
Humming noise coming from TTHide this!Advertise here!
Humming sound coming out of home stereo system instead of music what is causing this Zips1954 Solid State 18 22nd February 2017 07:58 PM
Humming Noise in my amplifier??? lock dogg Chip Amps 68 27th July 2016 09:27 AM
PC noise coming through speakers GuybrushT PC Based 4 20th November 2015 11:39 PM
Mirage S-8 Humming Noise cdonnelly20 Subwoofers 1 11th September 2013 12:39 PM
Can anyone ID this rather unhealthy noise coming from my amp? SatinMill Solid State 20 26th October 2011 04:49 PM
Copyright ©1999-2019 diyAudio
