roksan xerxes 20
roksan xerxes 20
Old 14th April 2019, 08:11 PM   #1
Gregje is online now Gregje  United Kingdom
Default roksan xerxes 20
Hi guys,
I normally do not post in this subforum.
I have Thorens 165 which I use occasionally. My question is about a more refined turn table.
Today my neighbour showed up asking me to help him with the adjustment of his Roksan Xerxes 20.
It looks like the platter is not horizontal. Apparently it used to be.
After removing the platter, you see four screws. The outer two control tilting in the south-west to north-east direction (what are the inner two for?). Underneath the inner platter there is another one (I haven't taken a picture of this one). It controls the south-west to north-east tilt.
The problem we had was that if you manage to get the inner platter level (see the picture with the spirit level) everything sinks in the north-west direction when we put the outer platter on. It looks like you have to overdo the adjustment with the T screw (the one under the inner platter) so that it will be all right in the end.
Is this normal? Is the whole adjustment an iterative procedure? Pretty long one too as the inner platter takes time to sink to its position.
Old 14th April 2019, 08:24 PM   #2
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
roksan xerxes 20
Wasn't this the model that had the sagging MDF arm board? The only solution was to replace it.
jeff
Old 14th April 2019, 08:44 PM   #3
Hmm... I will need to google it...
Old 14th April 2019, 08:57 PM   #4
Looks indeed like a known problem.
Are there any places where a fix has been described?
Old 14th April 2019, 10:48 PM   #5
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Sagging plinth...
hi. This problem was more prevalent with the original Xerxes. I bought a buggered Xerxes years ago and we came up with a fix that is still working to this day...Mike ended u with it. I think we altered the plinth to allow a squash ball (the audio cure all) to support it.
I'll have to check with Mike though...
stew -"A sane man in an insane world appears insane."
Old 14th April 2019, 10:57 PM   #6
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
roksan xerxes 20
The factory service manual states up to 3mm sag is ok. Mine has about 2mm (original) and works fine. protip with the xerxes is to put the outer platter on upside down then you can get at the adjustments with the correct mass loading.
Old 15th April 2019, 08:06 AM   #7
Thank you all!
After the adjustment I have done it might be ok.
Before I started the inner platter was clearly not level. After adjusting the T bolt I got the inner platter exactly right, if not a tiny bit too high in the NorthEast. I expect it to sag about 2mm (from what I have seen already). So it might be all right after all. If not we will put the outer platter upside down for the further adjustment.
@Nanook: If you recall what you have done please let me know. I will check with my neighbour tonight or tomorrow how his TT is doing.
Old 17th April 2019, 09:06 AM   #8
Nanook's Avatar
hi. The Pro tip is great!
Old 17th April 2019, 09:12 AM   #9
Nanook's Avatar
Default possible fix for sagging plinth..
Hi all.
As I posted previously, me and my audio partner Mike worked on an original Xerxes with a sagging plinth. If you take the outer plinth off (box and wooden top plate) the sub-chassis is obviously visible. Based on memory, we used a T nut or "nut-sert" and a corresponding machine screw to lift the plinth, when not it use. Over a period of time, the sagging portion of the plinth straightened. Not very scientific, but it worked.
If I can get a few photos I will and post them.
Old 19th April 2019, 07:13 AM   #10
I have been reading about xerxes on the net. I understand that The dreaded plinth sag exhibits itself in the previous version of the player, where the plinth has a C shaped cut in the mdf plinth to decouple the motor from the rest of the plinth. I think my neighbour's player (having an inner metal plinth) should be immune.
Anyway the neighbour came 2 day ago. The platter is level now, but the belt runs too high. Meanwhile I studied the manual so we should be able to correct this.
roksan xerxes 20Hide this!Advertise here!
Roksan XERXES XPS1 Power supply... HVfanatic Analogue Source 4 11th August 2016 03:20 PM
Roksan Xerxes Turntable. Oak finish dady Swap Meet 20 31st May 2016 10:06 AM
Roksan Xerxes Power Supply ISS2 (1985) - Schematic needed tiefbassuebertr Analogue Source 7 28th June 2013 02:03 PM
Roksan FR-5 ANWKLO Multi-Way 2 18th May 2013 11:43 AM
Xerxes 20 Dust Cover gz00 Analogue Source 1 8th December 2011 04:14 PM
Copyright ©1999-2019 diyAudio
