Need Help With CEC FR-808 Turntable Wiring
Old 15th April 2019, 12:47 AM   #21
Galu is offline Galu  Scotland
OK - It's getting late in the UK for puzzling out wiring diagrams, but it looks like the bottom right terminal may simply be a support terminal for the 200k resistor and that the 4 (K) 150 cap is a substitute for the failed can cap.
I hope Ralph will come back with his opinion.
Here's a pertinent question - did the motor run smoothly before you started the refurbishment? If so, we may be agonising over nothing!
Old 15th April 2019, 12:59 AM   #22
breadhead is offline breadhead  United States
Well, when I got it I turned it on and got zapped. A short somewhere. I don't know if the motor ran at all but I was planning on doing a re-cap.
Old 15th April 2019, 02:05 AM   #23
Well, that would have been good to know at the outset of this thread!
In the absence of any other opinions, I suggest you reinstate the circuit minus the can capacitor. You will have to support the 200k resistor along with the neutral and black connections some other way. Then measure the resistance between line and neutral (with switch at on position) and report back before 'going live'.
Old 25th April 2019, 01:01 PM   #24
Hello Galu. Do you own this table? If so, could you post a picture of the wiring? Thank you.
Jim
Old 25th April 2019, 03:11 PM   #25
No Jim, I do not own this table.
If a 'single-value capacitor motor', the main winding will be connected directly across line and neutral.
The auxiliary winding and series capacitor combination will also be connected across line and neutral.
Compare with the circuit diagram in post #6 where the 'run leg' is the main winding and the 'start leg' is the auxiliary winding.
Old 25th April 2019, 05:53 PM   #26
Thank you Galu. I will see what I can do.
Best,
Jim
Old 25th April 2019, 08:24 PM   #27
Hello again Galu. I measured resistance on the motor wires. I got 309 ohms black to brown, 175 ohms black to gray. I don't get a measurement from brown to gray?
Thank you,
Jim
Old 25th April 2019, 10:09 PM   #28
Mark Tillotson is offline Mark Tillotson
Thank you,
Jim
How can you not get a measurement?
Old 25th April 2019, 10:17 PM   #29
How or why I don't get a measurement I can not say....but I don't. Since my last post I wired the motor up as per the schematic I drew and posted earlier. The motor seems to run just fine. I just interpreted the three terminals on the bad can capacitor as connection points. I left the can cap out and wired as such. Again, motor is running now and seems fine.
Thank you,
Jim
Old 25th April 2019, 11:17 PM   #30
Well, after running for about 1/2 hour it seems that the motor is running very hot. Any ideas as to why? The capacitor that had been piggy-backed on measures approx. 8uF instead of the original 3.7uF. Could this be the problem?
Thank you!
Need Help With CEC FR-808 Turntable WiringHide this!Advertise here!
Wiring a line array: altering wiring schemes for matching levels w/woofer dave251 Multi-Way 6 5th February 2014 01:21 AM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
re-wiring the music centre turntable nottstu Everything Else 0 25th June 2005 08:45 PM
Copyright ©1999-2019 diyAudio
