sensible FM tuner choice
Old 11th April 2019, 10:11 PM   #41
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
On the little digituner, the op-amps are for a pair of small speakers, not the headphone jack. The headphone jack comes right from the...what appears to be a dsp chip.
As far as features, there's one. Long press the tuning knob and you can set the squelch/stereo/autotone threshold. It took me a couple of tries to figure out the hidden features. I wanted the 'clamp' set lighter to maximize the stereo field.
Long press one knob and then turn the other, sure was easier than 2 hours with a plastic screwdriver with an analog tuner.
I don't know the sensitivity figures, but is more sensitive than my big Technics tuner. I had only a 30" wire on the digituner, but it locks in every station. That kind of performance is normal for digituners.
On a digituner, the color, print, or brand on the op-amps doesn't affect the sound; but, what will do that is the power circuit. That's why I bought one that had only a radio rather than a complex multi-function model.
There was another function though. If plugged into a PC, it works as an output, not a tuner. Perhaps there should have been a double-pole on/off switch to disengage the 2 data lines. But, it wasn't difficult to find a phone charger.
For digital radio I use google home mini + chromecast-audio. There's no monthly payments. I just ask it to play something (genre, callsign, tunein name, or type) and it does. These two devices are set in a 'home group' so the chromecast-audio that is plugged into the amplifier plays the request. In fact, set the mini in the center, and you get triophonic sound (your 'listening chair' can be positioned anywhere in the room).
I did notice one oddity. Headphone sources, such as Laptop, chromecast-audio and digituner, have non-symmetric output and work better if the next stage (line amp or power amp) has a singleton input. I don't know why.
Old 16th April 2019, 05:47 PM   #42
keilau is offline keilau  United States
Are you referring to the Technic ST-9030 tuner? It is big. The spec may be state of the art in its day, but are good, not exceptional, compared to modern tuners.
Old 16th April 2019, 07:03 PM   #43
miklos is offline miklos  Hungary
miklos's Avatar
Originally Posted by keilau View Post
I shopped Magnum Dynalab too, but they are too expensive. Many Japanese brand made good FM tuner. The Denon is my favorite.
The 2 Marantz are newer (early 2000) design with microprocessor chip inside. I like the extra features and hope they would last longer.
Once a guy selling Magnum Dynalab in downton Toronto HiFi store. That time I was in to tuners. I wasn't impressed with the reception ability of tat tuner, I told him at he has an old beaten up Technics ST-9030 down in the annex, and bet that tuner will do better. He was laughed at me, but brought it up. The Technics had stations which did not exist on the Dynalab. I can say practically 99% of the hi end FM tuners made in Jappan, between the late seventies and the early 1990s.
miklos
Old 19th April 2019, 02:22 AM   #44
It sounds awfully like the Pro-Ject Tuner Box S2, without the fancy box and remote.
I wonder if it is the same one chip FM tuner TEA5767HN from NXP.
Old 19th April 2019, 03:36 PM   #45
On the little digituner, the chip is AC1552CG4R3F-E
There are others with similar performance. But, I shopped for one that didn't do anything other than tuner so the that power circuit (audible effects at small signal) didn't have or sound like anything other than tuner.
Old 19th April 2019, 03:51 PM   #46
Mike Gergen is offline Mike Gergen  United States
my tuner app on the phone. Streams better than the web, for me.
Old 20th April 2019, 01:05 PM   #47
Hi, may I ask what phone and what APP? I have not found an APP that allows me to stream FM station of my choice yet.
The idea of this FM tuner purchase is to listen to it through my audio system. It gives me good staging and dynamics of the sound.
sensible FM tuner choiceHide this!Advertise here!
Choice between F5 and F6 Insanoff Pass Labs 37 28th November 2015 12:46 AM
PIC Choice jwatts Digital Line Level 1 9th April 2011 08:46 AM
Fisher FM-50 tube tuner and Dynaco FM-3 tube tuner hatrack71 Swap Meet 5 25th January 2011 10:43 PM
Larsholt fm tuner front end for JLH tuner design-Any still available? djsb Analogue Source 0 25th December 2008 04:46 PM
Choice of DSP Severance Digital Line Level 5 22nd October 2008 05:49 PM
Copyright ©1999-2019 diyAudio
