sensible FM tuner choice
Old 31st March 2019, 02:29 AM   #21
paba is offline paba  Canada
IBOC noise is documented here is one report, you can skip to conclusion on page 45.
http://www.nprlabs.org/sites/nprlabs...l%20Report.zip
You can also google a bit on IBOC noise .
Paul
Old 31st March 2019, 02:47 AM   #22
keilau is offline keilau  United States
Default digital technology in Radio
Like it or not, it is difficult, if not impossible, to find a broadcast radio, for car or for home, that does not have a frequency synthesis front end.
Both the Marantz ST-6000 and ST7001 have frequency synthesis front end. The ST7001 front end is more integrated, thus, more compact in size. I suspect the same Marantz team designed both tuner and used newer components for the later ST7001. Both have decent sensitivity with ST7001 edged out ST-6000 by 0.1uV, practically identical.
Old 31st March 2019, 03:04 AM   #23
Paul
Paul, it is a 10 years old report. Do you experience a lot of IBOC noise when listening to FM at home? Particularly on headphone?
More importantly, it concluded that IBOC noise is mostly not a problem in component tuners. It should be no surprise to anyone. In car, it is so noisy that nobody cares.
Originally Posted by NPRLab_report2008
First, as stated before, results vary greatly among radios. In addition to cost (perhaps the biggest determinant of quality of a receiver), the type of receiver seems to correlate with susceptibility to host channel IBOC impairments, primarily due to a correlation between cost and type of receiver. When ranking all of the receivers tested by their MP1 mode results only, a handful of not particularly surprising trends become clear. Of all 7 of the boom boxes, all but one falls in the bottom half of the group of all 29 receivers tested, having higher than average impairment from IBOC. Conversely, of all 7 home stereos, all but 2 rise to the top half of the larger group. In a way, this grants broadcasters of high power IBOC some leeway with regard to analog host interference. It seems that receivers designed for careful listening, such as home stereo entertainment systems, have less trouble filtering out IBOC than portable stereos and clock radios, not intended for critical listening. These radios are more often used in situations where background environmental noise will overpower some or most of the decline in the analog receiver’s noise floor.
In the good old days, component tuner used to spec the 19KHz and 38KHz sub-carrier signal suppression. Filter in modern tuner are so good that no one spec those number anymore.
Old 31st March 2019, 03:12 PM   #24
BrianL is offline BrianL  United States
Keilau,
Have you looked at the Tuner Information Center - Vintage Stereo Tuners web site; they also have a mailing list. There is a huge amount of info there on tuners by FM tuner enthusiasts. Check it out if you haven't already.
bel
Old 31st March 2019, 06:02 PM   #25
Originally Posted by BrianL View Post
Keilau,
Yes, I am quite familiar with the TIC website and have consulted its reviews many times. But they have not covered the Marantz ST7001 and ST-15S1. So far, no respondent claims first hand experience with them yet,
The Denon is very well represented. I have used Denon TU-600 and TU-1500RDS in recent years based on information there. The TU-1500RDS performed beautifully.
I have WFMT in the Chicago area which has very high quality and good classical music selection. But selection of FM station is very limited. I decided not to spend the money on a collector's grade FM tuner. The Maraantz that I asked about are good enough for my purpose. I ended up looking at Marantz ST7001 and Marantz ST6000 due to performance, feature, availability and cost at the moment.
Old 31st March 2019, 06:10 PM   #26
rayma is offline rayma  United States
Originally Posted by keilau View Post
I already picked the ST7001.
Don't forget that you can also stream WFMT. No noise, no problems.
Listen | 98.7WFMT
Old 31st March 2019, 06:47 PM   #27
Default streaming WFMT
Listen | 98.7WFMT
My goal is for listening on my main, 2-channel, analogue sound system. Can I do it without a computer, Ipad, iPhone, Google Assistant or Amazan Alexa connected to the sound system?
I have Comcast/Xfinity for cable service. A Sony BDP-7200 Blu Ray player is connected to internet by CAT-5. I use a DAC to connect their digital sound output to my preamp.
Your advise is much appreciated.
Old 31st March 2019, 09:18 PM   #28
The Sony should be able to stream internet FM to your stereo system.
Check the owner's manual for details to see.
Old 31st March 2019, 11:57 PM   #29
possible, but I have not tried it yet. The Sony software has a number of music (Pandora etc.) and video (Hulu etc.) in the default menu, but I could not figure out how to add to them using URL yet.
I suspect that I can access WFMT using its internet browser, but the screen keyboard is a pain in the neck to use.
I hope that other Sony user can help me out. If it works, I will not need a FM tuner after all.
Old 1st April 2019, 12:00 AM   #30
I suspect that I can access using its internet browser, but the screen
A newer model may be easier to use, try a Best Buy or similar store
if no one here can help.
sensible FM tuner choiceHide this!Advertise here!
Choice between F5 and F6 Insanoff Pass Labs 37 28th November 2015 12:46 AM
PIC Choice jwatts Digital Line Level 1 9th April 2011 08:46 AM
Fisher FM-50 tube tuner and Dynaco FM-3 tube tuner hatrack71 Swap Meet 5 25th January 2011 10:43 PM
Larsholt fm tuner front end for JLH tuner design-Any still available? djsb Analogue Source 0 25th December 2008 04:46 PM
Choice of DSP Severance Digital Line Level 5 22nd October 2008 05:49 PM
Copyright ©1999-2019 diyAudio
