Patrick Turner on Turner Audio had a very good one too, but you can try two or three different ones...you don't need fantastic precision with riaa.I was able to replicate 20khz square waves with two different filters, way more than what you really need .What you really look after is the response under 500hz .
unfortunately there's no simplicity of construction with anti-riaa filters.You need to get the exact values in picofarads.Mica, polystyrene, pps capacitors, low noise precision resistors...but parallel/series resistors and parallel capacitors will get you any value.
It feels good to get 0.1dB accuracy but you would be hard pressed to find a cartridge where 5% (+-0.5dB) values would matter.
- Analogue Source
- Reverse RIAA circuit
