Yamaha TX540 tuner not tuning
Old 18th March 2019, 09:53 AM   #21
Glenn E is offline Glenn E
Hi Mooly, I have 5.2V on pin 17 and not changing as frequency changes (or maybe incresasing very very slowly if I let it cycle on auto tuning) but it should be 2.4V. So, the problem may be with the PLL or somewhere further back. I'm at the limits of my troubleshooting ability tracing back past the PLL. Glenn
Old 18th March 2019, 10:09 AM   #22
Hi Mooly, ignore my last reply. I was reading wrong chip. Actually no voltage on pin 17.
Glenn
Old 18th March 2019, 10:12 AM   #23
Mooly's Avatar
A DVM will not show a true reading because the voltage is a logic level that constantly changes. Scroll down this link to 'Duty Cycle'
Pulse-width modulation - Wikipedia
If you have 5 volts on pin 17, then you should find that if you short the gate of the FET o ground (that the 10k from pin 17 goes to) that the tuning line VT changes dramatically. Don't short pin 17 directly though, do it at the end of the resistor.
Old 18th March 2019, 10:15 AM   #24
Mooly's Avatar
Lol no problem.
Is the 5 volt supply to the chip OK?
Old 18th March 2019, 10:23 AM   #25
Not sure which pin is the 5 volt supply. Looks like pins 5, 15 and 16 should read about 5 volts. I'll check them. Glenn
Old 18th March 2019, 10:24 AM   #26
Mooly's Avatar
Vdd is the supply pin, Vss is ground.
Old 18th March 2019, 10:30 AM   #27
Pins 6 (not 5), 15 and 16 all reading between 5.2 and 5.5 volts. Glenn
Old 18th March 2019, 10:31 AM   #28
That is pin 15 so looks OK. Glenn
Old 18th March 2019, 10:40 AM   #29
Mooly's Avatar
So the supplies seem OK. This is getting into scope territory I'm afraid as you are limited with what you can see with a DVM. Although the scope can't reveal whether the 'data' content is good or not, it does provide massive clues in terms of what is there and the amplitude and so on. Also if data is present then its usually (in my experience) correct.
You could try connecting a 1 k resistor from the 5 volt supply to the gate of the input FET and seeing if that swings the voltage on the tuning volts line. That is a very crude test of the transistor stage.
Data sheet for LM7000:
HTTP 301 This page has been moved
Old 18th March 2019, 11:18 AM   #30
Not sure which is the input FET. Can't pick it on the schematic. Glenn
Yamaha TX540 tuner not tuningHide this!Advertise here!
FM Tuner keeps on tuning DaniTD Digital Source 10 5th July 2016 05:05 PM
Yamaha TX-492 AM/FM Tuner $150 GTDS Swap Meet 0 16th February 2014 07:34 PM
Yamaha CDX-596 schematic needed for tuning Goetz Digital Source 3 7th February 2012 01:59 PM
Yamaha T-85 Fm tuner mods. pdul Solid State 7 10th August 2010 04:24 PM
Yamaha T80 tuner jean-paul Solid State 3 23rd May 2003 08:06 AM
Copyright ©1999-2019 diyAudio
