Sony PS-X800 adjustment (Forward Speed Adjustment)
Old 10th February 2019, 03:23 PM   #1
hironimo is offline hironimo  Switzerland
Question Sony PS-X800 adjustment (Forward Speed Adjustment)
Hi
I'm adjusting the Sony PS-X800 and now I'm at Forward Speed Adjusting (Page 22 Service Manual) I'm trying to measure the 100Hz (33rpm) and the 150Hz (45rpm) as described in the manual (with a RIGOL DS1054 ) but I don't get it what exactly to do, what is the meaning of promptly adjust the RV ? maybe someone has experience withe adjustment procedure of the PS-X800
the steps described in the manual before this point I was able to follow.
thanks
Hironimo
File Type: png Bildschirmfoto 2019-02-10 um 17.10.00.png (588.2 KB, 11 views)
File Type: jpg Bildschirmfoto 2019-02-10 um 17.10.18.jpg (133.2 KB, 10 views)
Old 10th February 2019, 03:51 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Adjust the preset for either 100 or 150HZ as described. Adjust and check. Don't slowly adjust the presets.
Power off and on again to check your measurements.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 10th February 2019, 04:08 PM   #3
Hi
Thanks for your answer what I'm doing is connect the probe to Pin 5 of IC 301 I think that what it meant to connect, and ground to ground and then I start playing at 33rpm but what I measure is frequency of several Khz instead of 100 or 150 hz also I'm not shure if something is wrong with the circuit or if I'm just not doing it right
thanks
hironimo
Sony PS-X800 adjustment (Forward Speed Adjustment)Hide this!Advertise here!
Sony TA-5650 restoration - Bias adjustment MattiaM Solid State 10 27th January 2018 01:09 PM
Sony KSS-190A adjustment Mike P Digital Source 8 10th March 2017 10:20 PM
Technics Sp-10mkII speed adjustment SebastienL Analogue Source 0 20th April 2012 01:00 PM
CD-adjustment with Sony YEDS-18 disk LenzMich Digital Source 2 31st August 2011 06:52 AM
Sony PS-X800 Zero Balance Adjustment procedure help Professor Bizzt Analogue Source 0 1st July 2010 10:41 PM
Copyright ©1999-2019 diyAudio
