Phono cartridge self resonance
Old 1st February 2019, 06:02 AM   #51
davidsrsb is offline davidsrsb  Malaysia
No, coupled layered windings and distributed capacitance won't give us the far too resistive phase shifts measured
Old 1st February 2019, 08:33 AM   #52
billshurv is online now billshurv  United Kingdom
billshurv's Avatar
Another suspect to tick off the list (clutching at straws here I know). With a transamp we are rolling off anywhere from 50-500Hz first order. So by 2kHz we are at minimum 12dB down (other than Grado).
IF eddy currents are involved AND if lower level reduces eddy currents would this explain things?
Old 1st February 2019, 10:16 AM   #53
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
I still vote the mid-dip to be some cantilever/suspension/damping effect. The Grado looks just like the "load the magnets" plot (I trust the constant velocity track on the CBS Labs LP).
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 1st February 2019, 10:26 AM   #54
billshurv's Avatar
well we can test that comparing OM and superOM when I post a super body to LD. He gets a flat response on a carrtridge that gets a dip with 47k loading...
New Lamps for Old 2M has the split pins. least dip. I'm curious to chase this to a logical conclusion even if totally and utterly wrong.
Old 1st February 2019, 11:01 AM   #55
Hans Polak is offline Hans Polak  Netherlands
Originally Posted by scott wurcer View Post
Below are two examples, I picked Rod Elliot's split L model just as an example. The first is loaded (100pF||47k) second is unloaded. Both of these are noise only. We can measure the series resistance and the basic low frequency inductance, the noise signature should reflect the loss and, if present, a resonance will give the internal parallel C.
With much difficulty I was able to measure the noise of the DA in a 50pF mica capacitor. Thermo-dynamically all electrical loss mechanisms have an associated noise.
Thanks for the references, they show the possibility of non-minimum phase in these measurements (?).
Scott,
Could you show Rod Elliot's model that you used to create the noise image.
I have tried on the internet, but couldn't find this split L model.
Hans
Old 1st February 2019, 11:12 AM   #56
billshurv's Avatar
Magnetic Phono Pickup Cartridges
Old 1st February 2019, 11:24 AM   #57
luckythedog is offline luckythedog  United Kingdom
Been trying to go back a few steps on this and invoke spherical cows. Someone tell me where I'm making a wrong assumption or have physics upside down.
Assuming eddy currents exist and assuming the generator in a MM cart is so inefficient that the wiggling magnet can be ignored.
1. In 47k world eddy currents will be level dependent (possibly testable).
2. For an EC to flow in the iron core, then current must flow in the coil
3. For current to flow there must be a voltage across the windings.
4. In the low-Z world the voltage across the windings is much reduced as the voltage across the cartridge pins tends to zero and only the coil resistance limits this
5. low voltage also means low current in this case (not sure about that)
If all the above is correct then a low Z preamp will show a lot less tendency for a midrange dip
Conversely a higher Z load might increase the dip?
Load the Magnets!!! - [English] has some measurements that might indicate this is the case. Given my lack of trust for pink noise tracks on test records I consider salt is needed, but we might be onto (backonto?) something.
What have I missed?
Hi Bill, I think its well worth exploring theory.
Eddy currents arise in any conductor where there is a change of flux. In a MM cartridge this arises in the coil core because either a magnet waggles (moving magnet) or a pole piece waggles and disrupts a static field (moving iron). In a MI cartridge it also arises in the pole piece.
Eddy current is proportional to rate of change of flux, ie velocity of the moving part. So in vinyl playback that means instantaneous programme level, more or less.
The eddy current itself has associated flux, which acts to reduce incident flux. Then reduction in incident flux is proportional to rate of change of flux, ie programme level. So eddy current is a second order differential equation involving both velocity and acceleration of stylus motion, ie programme level and slew rate.
What shows up as effect on cartridge voltage output is proportional to rate of change of reduction in incident flux and that is a function of both velocity and acceleration of stylus motion, ie programme level and slew rate.
The effect of drawing coil current is to reduce incident flux.
In spherical cow land, one is allowed to ignore constants which in the real world determine how big the effect is and the relative importance of programme level and slew rate.
In a f sweep at constant level, programme slew rate depends on both level and frequency.
LD
Old 1st February 2019, 11:26 AM   #58
Thanks Bill
Old 1st February 2019, 12:20 PM   #59
gpapag is offline gpapag  Greece
gpapag's Avatar
Thanks Bill
I think in this article Rod has it backwards. He writes (2nd par below Fig.4)
Cartridge manufacturers often use cantilever resonance to attempt to get a flat response up to the highest frequencies,”.
What I see happening is that the cantilever resonances is the cause of the anomaly in freq response which manufacturers try to compensate by trimming the electrical motor and it’s electrical loading.
He also measures and simulates with the 47kOhm resistor in series with the voltage generator and not in parallel to it.
I don’t get this.
It is a loading resistor.
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 1st February 2019, 12:23 PM   #60
It is straightforward in principle to devise a cantilever with a resonance well clear of the audioband, if desired.
LD
Phono cartridge self resonanceHide this!Advertise here!
WTB: Phono Cartridge Rodeodave Swap Meet 6 18th April 2018 03:12 PM
Philips GP 390 phono cartridge? msdin Analogue Source 1 9th January 2016 11:26 AM
measuring tonearm/cartridge combination resonance neuperg Analogue Source 2 25th June 2009 08:32 AM
a little help with phono cartridge bferjanc Analogue Source 1 22nd March 2009 04:25 PM
WTB : New phono Cartridge/stylus Ilianh Swap Meet 3 22nd June 2003 03:58 AM
Copyright ©1999-2019 diyAudio
