Phono cartridge self resonance
Old 19th January 2019, 04:28 PM   #11
luckythedog is offline luckythedog  United Kingdom
Originally Posted by scott wurcer View Post
Thinking around a late coffee, isn't there only one component here a big distributed R/L/C.
Life itself is a transmission line, one comes to realise. Yes, if its a single layer sequentially wound coil. After that it gets tricky because multilayer coils have cross coupled C between turns on different layers. There's not much literature on it, AFAIK.
LD
Old 19th January 2019, 05:54 PM   #12
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by billshurv View Post
The main measurements from George are here Cartridge dynamic behaviour . Too many toddlers around for me to deeply re-read at the moment
Some of the coil measurement basics FYI.
https://link.springer.com/content/pd...9075-2%2F1.pdf
Thankfully the toddlers belong to my children now. I might try some measurements (a few more bins to unpack) . Lucky, I assume most carts are wound with something like #50 wire any idea on turns/layers (just enough to make a guess if I find any good references). I have a sawed open Grado somewhere but they are the exception.
EDIT - Most references, obviously, seem to focus on high Q RF applications.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 19th January 2019, 09:31 PM   #13
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
I have one sacrificed cartridge I could try and count and a couple more I could give up for the cause. How many samples are we likely to need to conclude if self resonace ever ocurs in the audio band?
Old 20th January 2019, 12:34 AM   #14
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by luckythedog View Post
So why doesn't MM coil parasitic C show up in after dinner conversations, audible performance, and measurements affecting f response etc etc ?...
It is lumped-in with the capacitance of the wiring and the tube grid capacitance.
Most of this C being unavoidable (until headshell preamps), the industry convention is to apply 47K and adjust capacitance to get resonance at "the top of the audio band".
This allows the cart designer to trim the L-R-C bump to compensate the top octave of the pickup.
While interwinding capacitance is a thing, on a simple winding like this it just builds-up and can be sufficiently approximated as a single C.
Old 20th January 2019, 12:48 AM   #15
billshurv's Avatar
We tried to find evidence of this. There are several seemingly compelling models that suggest this bump is needed, but if you then measure using a preamp that is free from Capacitive loading issues you don't get a top octave roll off. At least on anything made since about 1972.
But some of the data still doesn't fully make sense....
Old 21st January 2019, 05:37 PM   #16
billshurv's Avatar
back on coil self resonance not sure if this is of use Moving-Magnet Head Amp - without RIAA appears to show a distinct notch at 50kHz.
Old 25th January 2019, 09:43 AM   #17
gpapag is offline gpapag  Greece
gpapag's Avatar
LD and Bill’s call for electrical self resonance
50 Ohm signal generator in series with a Shure M97xE to single-ended Aurak RIAA preamplifier. M97 self resonance shows up a bit above 40kHz
mechanical resonance in MMs
Input resistance of Aurak is here
Manual spot frequency measurement
Test record playback
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 25th January 2019, 11:03 PM   #18
Originally Posted by gpapag View Post
Guys we are off track...….
I thought that, when I realised the negative input impedance stage drives the non-inverting input of the op-amp. Then the simulator confirms, curiously, that the stage overall is inverting...…..(!?!) Phew so that's fair game at least
Thanks for the links to your coil self-resonance measurements, George. That's how I recall it. I still think that's odd though, perhaps some winding method. This would equally apply to audio transformers wouldn't it, which is a better charted water?
LD
Old 26th January 2019, 09:04 AM   #19
A quick look at self-resonance of good quality mic transformers suggests self-resonance at c 250kHz. I think such transformers are prob magnetically similar enough to cartridges to consider it not to be an issue, and George's tests confirm this.
Some reference to self C not depending proportionally on number of turns, diminishing increases with each extra turn.
I don't understand it, but happily accept it. Besides, it's good news for low Z input impedance preamps.
LD
Old 26th January 2019, 02:11 PM   #20
I originally though of building a distributed self resonance model via the L of one layer and the C to the next but that soon makes no sense since the C's are in series and as L grows the C goes down. I suspect the entire structure along with the mutual coupling is involved.
Phono cartridge self resonanceHide this!Advertise here!
WTB: Phono Cartridge Rodeodave Swap Meet 6 18th April 2018 04:12 PM
Philips GP 390 phono cartridge? msdin Analogue Source 1 9th January 2016 12:26 PM
measuring tonearm/cartridge combination resonance neuperg Analogue Source 2 25th June 2009 09:32 AM
a little help with phono cartridge bferjanc Analogue Source 1 22nd March 2009 05:25 PM
WTB : New phono Cartridge/stylus Ilianh Swap Meet 3 22nd June 2003 04:58 AM
Copyright ©1999-2019 diyAudio
