Micro Seiki MA 707 help please
Old 15th January 2019, 07:37 AM   #1
Cold Beer is offline Cold Beer  Croatia
Default Micro Seiki MA 707 help please
I recently bought Micro Seiki MA 707 tonearm without two weights. The slider one and additional weight are missing. So, I have a small request for the owners: If you have any of them, I would appreciate if you could measure weight and dimensions of them, so I could fabricate them according to originals.
Thank you
Old 15th January 2019, 10:30 AM   #2
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Webshop Micro-Seiki.nl
Old 18th January 2019, 01:47 PM   #3
No help from them. They don't support diy people, only want to sell their stuff.
Anyone else? Help please
Old 18th January 2019, 05:09 PM   #4
AVWERK is offline AVWERK  United States
AVWERK's Avatar
I have this tonearm somewhere in my mess. If I can find it, I will post the info for you.
Did Micro ever publish a graph on where to place the adjustable mass to a specific cartridges compliance ? Otherwise its just a guesstimate
David
Old 18th January 2019, 05:47 PM   #5
academia50 is offline academia50  Argentina
That photo belongs to me ! , but do not worry, I will not make any claim about it !
I remember that I had published the data you need using my wife's kitchen scales ....
Look here:
Moving Coil High Output for tonearm MicroSeiki MA-707- Vinyl Engine
Old 18th January 2019, 06:17 PM   #6
David
Hi David, info that you are looking for can be downloaded from here:
Library Downloads - Vinyl Engine
@ Academia, - thank you man, i have weight now. If I did my math well, slider is around 14-15 gms, additional weight is 28 grams. Correct? Dimensions?
Old 18th January 2019, 07:38 PM   #7
Yes, those are the correct weights according to the calibration of my balance .....
Let me take the right dimensions and I'll pass them to you.
What you have to do in the meantime is to try the type of thread that leads in the end, that surpasses my knowledge of mechanics ... I do not think it is a DIN step but of English standards, you can try with provisional screws trying to screw them gently in the arm housing (female) until you find the correct one.
Old 18th January 2019, 09:16 PM   #8
No problems with thread. I can do metric, fine metric, or whitworth, no problem. It will be easy to find out when my tonearm arrives
Old 18th January 2019, 10:48 PM   #9
AVWERK's Avatar
It is 12.5 mm dia.
Side screw all the way in , the combined length is 19 mm
David
Old 21st January 2019, 06:46 PM   #10
It is 12.5 mm dia.
David
Black part made of metal like screw? Or plastic?
Micro Seiki MA 707 help pleaseHide this!Advertise here!
Micro Seiki BL-10X and MA-500 tone arm ksporry Analogue Source 7 22nd February 2017 07:49 PM
Micro Seiki Tonearm. MiiB Analogue Source 2 28th May 2007 04:14 PM
Micro-seiki DQX-500 gotster Analogue Source 0 11th January 2005 08:44 PM
Micro Seiki MC ktigerb Analogue Source 0 27th May 2003 10:16 AM
Copyright ©1999-2019 diyAudio
