Moving-Magnet Head Amp - without RIAA
Old 8th January 2019, 06:46 AM   #11
rsdio is offline rsdio  United States
Originally Posted by BrianL View Post
There is no reason why you can't generate +/- supplies from your wall-wart. I believe Doug Self shows how in his book. It's pretty easy and works well as long as the current draw isn't too high as each 'half' is being charged with half-wave rectifiers.
Thanks.
I've had success with the voltage doubling technique that Doug mentions in Chapter 25, under "Dual supplies from a single winding," but that was for a different project that required a +/-7V supply. It actually worked "too" well, in that the 12 VAC wall wart produced more than 34V peak-to-peak at the regulator inputs, which exceeded the 25V input rating of the positive regulator. The negative regulator can handle 35V to 40V inputs, so that one worked fine.
I'm a little reluctant to use half-wave rectification, because for some reason I assume that it would produce more noise. There'd be more ripple, and I'm already cramped for space with regard to capacitors. Maybe I need a bigger case!
All things considered, I think that my biggest objection to bipolar versus a unipolar supply is the extra components. I need a second regulator, and two additional smoothing capacitors for the input and output of that regulator. I'm already cramped in the case, having only 22 mm height for the capacitors, and the 18 mm diameter space that's available limits me to 1300 F.
What's funny is that Self compares unipolar supplies with the caveat that extra components are needed in the form of DC blocking capacitors in some of the places where gain resistors might normally be grounded. In my practical case, those additional capacitors are much smaller in physical size than the extra capacitors needed for a negative supply.
I still need to SPICE up the circuit so far in order to estimate how much supply current I will need. That might answer a few questions about component sizing.
I'll probably design a second version of this No-RIAA Phono Preamp using a bipolar supply, but only after I've secured an affordable case that has in integrated phono ground lug screw.
Old 8th January 2019, 06:57 AM   #12
Originally Posted by rayfutrell View Post
You may be interested in this Revox B291 turntable schematic on page 6-14. Revox called it an impedance converter but it's just an RIAA preamp without the RIAA.
STUDER REVOX B291 SM Service Manual download, schematics, eeprom, repair info for electronics experts
Thank you!
That is interesting, but if I found the right page it seems to be an all-transistor circuit. I may not be satisfied with the distortion performance of an all-transistor design, so I'll probably stick with the NJM5534DD plus LM4562N design that I'm working on now.
When I upgrade to Moving-coil, I'm thinking of building Self's hybrid transistor plus op-amp preamp in Chapter 12. He describes a flat (no RIAA) head amp for MC that's designed for feeding a standard MM phono preamp. That would be almost ideal for my Metric Halo Labs ADC, although I might have to increase the gain.
Old 8th January 2019, 07:23 AM   #13
Originally Posted by PRR View Post
Originally Posted by rsdio
....the output would be at standard -10 dBV unbalanced....
At what frequency??
If we define the RIAA-corrected response to be "flat", then a non-corrected response will be 20dB down at 50Hz and 20dB up at 20KHz.
Your question is heading in the right direction. At the very least it's related to questions that puzzled me for a while.
Thinking from a practical sense, though, -10 dBV is basically setting an overall level, regardless of frequency. All of the frequencies in the total signal have to be within the peak-to-peak bounds of a typical -10 dBV input. I don't happen to know what level is considered to be safe from clipping for unbalanced gear, since they all seem to report RMS levels.
If my hottest MM cart puts out 8 mVrms, then I assume I have room for almost 32 dB of gain to stay within -10 dBV levels.
In other words, I think that we can safely ignore the levels at specific frequencies. As long as the total signal can be digitized by the ADC without clipping, then the RIAA curve can be applied in DSP. My RIAA plugin has an automatically-calculated gain that guarantees that the output levels will not exceed 0 dBFS (so long as the input levels don't exceed 0 dBFS - it's a floating point DSP).
Taking a rough guess: if RIAA gain of 100 at 1KHz gives a good nominal line level, take the caps and bass R out of the RIAA and it will probably give a tolerable level
I started with one of Doug's phono circuits and tried to delete the EQ caps while retaining the basic "gain" of the op-amp. I ended up with something around 29 dB to 30 dB of gain. When I later went back and compared the 8 mV output spec from the cart with the 316 mV nominal level of -10 dBV, I also got +31.9 dB, which is about the same.
Old 8th January 2019, 07:44 AM   #14
Originally Posted by sgrossklass View Post
A flat amp is going to require substantially more GBW and slew rate than one with active RIAA. I would use at least two opamp stages at 20 dB each.
That's an excellent suggestion. I was already thinking of using two stages, one at +30 dB for phono to unbalanced levels (whose outputs I may never use) followed by an unbalanced to balanced stage with just under +12 dB. That's a total of +42 dB. Since the gain will be conveniently set by resistors, I should be able to try your approach of more evenly distributing that gain. The caveats are that my unbalanced outputs would only have a single stage (but, as I said, I'll probably never use those outputs) in either case, and if I change the ratio between the stages then my unbalanced output would be weaker (although the balanced outputs could remain basically the same).
Question: Since RIAA boosts bass, doesn't the RIAA output require even more slew rate? I can see how the gain bandwidth might be relaxed by cutting the highs, though.
Maybe start off with NE5534As (910/100 ohm) and continue with a good FET input dual of highish slew rate (AD8620 w/ 4k3/470 ohm? I know they'll only do +/-13 V, but in this application a +/-9..12 V supply would be plenty).
At the moment, I'm planning on NJM5534DD chips (split stereo) followed by two LM4562N (each handling +/- for a single channel). The LM4562N has standard dual op-amp pinouts, so I can try the AD8620. The caveat here is that both of my op-amp choices can handle a +34V supply, but I'd need to scale that back before installing the AD8620.
Software / DSP RIAA is doable (and has been done before, even commercially) but you do want a decent ADC, and it goes without saying that you do not want to be fighting a ground loop issue in your setup, as the amp-DAC connection is going to be ~20 dB more critical in this regard.
I'm happy with my RIAA implementation, but the ADC has basically the same.
My ADC is the Metric Halo Labs LIO-8, which far exceeds decent.
Your ground loop comments are spot on. The whole instigation of this project was grounding issues. I've probably solved the grounding issues with the passive PCB, but now I'm seeing ultrasonic noise pickup, and I assume that going active will solve that.
I'm not entirely convinced that I "need" balanced outputs, but since the LIO-8 has balanced inputs, I figure it's worth a couple of extra LM4562 stages to get maybe 3 dB better S/N.
As a compromise, I might try implementing the second gain stage as a good approximation of an integrator across the entire audio bandwidth. (Maybe inverting, 2k2 + 6.8n poly || 1M?) This characteristic would be easily reversed in software, and any parts tolerances would only result in some channel imbalance (easily enough brought in line either in software or by making one channel's gain slightly variable with a trimpot, applying a signal split to both channels to adjust) or frequency response deviations in the subsonic range. It would make ADC high-frequency noise a bit more critical, of course, but in the days of 100+ dB ADCs I don't see that as a major problem.
That's a very interesting idea. I'm concerned that it adds another variable that I'll just need to compensate for.
Old 8th January 2019, 09:13 AM   #15
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
In terms of gain you have to deal with the gearchange of thinking in dBV to thinking in dBFS. I find the easiest way to look at it is to make the 0dB ref off a test record equal to -23 to -26dBFS. So for the LIO-8 set to +22dBu for 0dBFS you are roughly talking 0dB record=0dBu into the ADC. Or 40dB.
The handy thing about this is that most ADC designed for studio use have a green light that comes on at -23dBFS to indicate signal present. Handy kwik kal there
That LIO is a lot hotter than most stuff I am likely to use, so I can wuss out with a lot less gain. I only need 40dB gain for LOMC.
BTW this article Scott wrote for Linear Audio is well worth the €2.99.
For those who don't like rolling PCBs/vero there is this Phono Transfer System Construction Information - Pro Audio Design Forum Balanced in and out with minimal parts count and the option of a switchable RIAA if you want that.
Old 9th January 2019, 05:46 AM   #16
Good points.
If I were targeting a +4 dBu mixing console, then I would not bother to boost the gain so much that I'd need to engage the attenuating pads. That sorta defeats the purpose because you have to add resistance.
The LIO-8 has digital controlled gain, at least as far as I understand, so it seems like almost any gain that falls within the range will be good enough. I'm quite familiar with setting the input gain levels for vinyl sources on the ULN-2 and LIO-8, and I always leave plenty of headroom to avoid any chance of clipping at 0 dBFS.
I'm more thinking of dialing in a nominal +4 dBu signal level rather than going for the extremes (high or low) of what the Metric Halo Labs MobileIO can handle.
Thankfully, gain is the one thing that should be relatively easy to change since I'm designing for through-hole metal film resistors. I mean, I also have soldering tweezers for thin film resistors, but I don't know that I'm cramped for space quite enough to incur the cost of SMD assembly.
Old 9th January 2019, 05:50 AM   #17
Originally Posted by billshurv View Post
BTW this article Scott wrote for Linear Audio is well worth the 2.99.
Thanks! Those threads look very promising due to the similar goals.
I got the impression that Scott's Linear Audio article is separate from the Pro Audio Design Forum, but I didn't see a link or full name. Did I miss something?
Old 10th January 2019, 09:20 AM   #18
billshurv's Avatar
Yes, two seperate designs, both for similar goals. Scott's work is interesting for people who happen to have an ADC at home that has phantom mic inputs and opens up some interesting options for ripping vinyl using a battery powered field recorder. No ground loops guaranteed!
I even have one thing to try with a focusrite mic input where you just load down the cartridge to get the 75us pole passively before you reach the amplifier. This will increase noise but for fun worth trying.
worth checking at what gain your LIO has the lowest noise and target that.
Old 11th January 2019, 03:03 AM   #19
I'm probably not trying hard enough (haven't searched "Linear Audio" for articles by "Scott") but could you at least mention his last name? An actual link would be awesome, although I gather that it's not a free download.
Excellent suggestion. I'll look into it.
Old 11th January 2019, 09:23 AM   #20
billshurv's Avatar
Article is here Linear Audio | your tech audio resource
His head amp ideas are posted on here which I should have linked. Many ways to skin this particular cat!
Moving-Magnet Head Amp - without RIAAHide this!Advertise here!
Moving Magnet Sub with accelerometers and DSP eriksquires Multi-Way 0 27th May 2018 03:57 PM
no moving coil no fixed magnet and no cone simeon w Planars & Exotics 49 13th November 2016 09:05 PM
What currently available moving magnet cartridge is the best.??????.... oldheathkitphil Analogue Source 28 12th April 2008 02:16 PM
Moving Magnet Phono Load 6f6 Analogue Source 6 16th February 2007 10:25 PM
any moving magnet drivers? jcx Multi-Way 0 8th December 2004 03:23 AM
Copyright ©1999-2019 diyAudio
