Moving-Magnet Head Amp - without RIAA
Old 3rd March 2019, 01:30 AM   #111
rsdio is offline rsdio  United States
Here is the main board for the preamp. The LED hasn't been soldered on yet (still waiting for a different color).
The dimensions of the boards are constrained by the 32mm x 64mm x 104mm case that I found which has a turntable grounding screw on the outside. I didn't want to DIY the case, too.
Old 3rd March 2019, 02:38 PM   #112
Hans Polak is offline Hans Polak  Netherlands
Originally Posted by rsdio View Post
I have a 1 MΩ resistor now, and have reduced the gain of the first stage to 20.1x (+26 dB) to create a virtual 47.4 kΩ load.
I didn't understand what you were suggesting the first time, but I could disconnect the 1 MΩ and solder a 47 kΩ with 1 lead on the PCB and the other lead grounded. I might try that to see if there is any difference, but I doubt I could measure it.
With the lower gain, noise improvement is now 3.0dB just a little bit less.
What I suggested was to use not one but two resistors in series.
In this new case 47K + 950K instead of 1 Meg.
All you have to do to notice any difference is to gnd the connection between 47k and 950k,
Hans
Moving-Magnet Head Amp - without RIAAHide this!Advertise here!
Moving Magnet Sub with accelerometers and DSP eriksquires Multi-Way 0 27th May 2018 02:57 PM
no moving coil no fixed magnet and no cone simeon w Planars & Exotics 49 13th November 2016 08:05 PM
What currently available moving magnet cartridge is the best.??????.... oldheathkitphil Analogue Source 28 12th April 2008 01:16 PM
Moving Magnet Phono Load 6f6 Analogue Source 6 16th February 2007 09:25 PM
any moving magnet drivers? jcx Multi-Way 0 8th December 2004 02:23 AM
Copyright ©1999-2019 diyAudio
