2007 Rega P2 upgrade
Old 9th December 2018, 08:01 PM   #1
cbutterworth is offline cbutterworth  United States
Default 2007 Rega P2 upgrade
I have a Rega P2 that I purchased new in around 2005. I do not want to replace it, but am pondering some upgrades. I have some questions regarding this:
1. What type of cartridge came with it? It is red, very like the Bias.
2. Would it have the 24V quieter motor? It does not have a plugin adapter.
So what upgrades would give me the most “bang for my buck”? Considered options that I can think of are:
A. Upgraded cartridge - Elys?
B. New optiwhite platter? The original is the MDF.
C. Upgraded motor?
D. Rega wool record mat? The original came with a black felt pad, which may actually be the wool one.
The equipment that I use it with is pretty good IMO:
Phono-pre: Hagtech original Cornet (newest iteration Cornet3 - MM Vacuum Tube Phono Preamp)
Amp: TubeLab SimpleSE single-ended; AKSA 55n
Speakers: Pensil 10.2; Vandersteen 2
I’d welcome suggestions, advice, comments.
Thanks,
Charlie
Old 9th December 2018, 08:09 PM   #2
Hikari1 is offline Hikari1  United States
A) cartridge and appropriate spacer. This will be the most dramatic change.
B) 24v motor
C) glass platter and aluminum sub platter
Add those up...might be better off buying a used rp6 or p5 or p3-24 or a new p series.
Old 10th December 2018, 07:49 PM   #3
Upgrade to a P3 with Elys cartridge is beyond my means right now.
It seems that my P2 has the Bias cartridge already.
So, if I were to make a cartridge upgrade my thoughts are between:
Rega Elys
Ortofon 2m Blue
Ortofon 2m Bronze
The latter would max my budget.
I have heard that Ortofons are brighter and mor “analytical” than the Regas. However, given my tubed preamp and SE amp, maybe that wouldn’t matter. I’d prefer warmer over analytical. But Ortofon coupled with tubed amplification may be just what I need.
Ideas?
Old 10th December 2018, 07:55 PM   #4
I haven't heard any Rega Carts. I have a P5 with a 2M bronze...I like it a lot. But I havent heard a lot of different cartridges on this table...just the 2M bronze and a Denon 110.
Old 10th December 2018, 11:27 PM   #5
Thanks, seeing as I don’t have the funds right now, I can save the Bronze unless a cheaper option shows up.
With regard to the Denon, my concern is the cartridge output. The Rega Bias puts out over 5mV, but the Denon is around 2mV. I am concerned that the 43dB gain of the preamp with the low wattage of the SE will underpower even my single-drive speakers.
Charlie
Old 11th December 2018, 02:47 AM   #6
Nine Cartridges Reviewed, Compared and File Identities Revealed! | Analog Planet
This is a good read.
2007 Rega P2 upgradeHide this!Advertise here!
Anyone done the Rega 24V Motor Upgrade? craigtone Analogue Source 0 12th February 2015 07:46 PM
Rega P3 motor upgrade install not right - help please simonl8353 Analogue Source 2 18th August 2009 11:28 AM
upgrade my rega, or buy an alternative? graeme uk Analogue Source 6 14th May 2006 06:49 AM
Has anyone tried these Rega/Linn TT 'upgrade kits'? Saurav Analogue Source 2 30th January 2004 06:58 AM
rega's upgrade kit GAK Analogue Source 4 27th January 2004 03:50 AM
