Hello ! The gain can be changed in R6 and R16 values (according to the Jim Salabim scheme).......
I think "R16" should be "R19"?
When using BC 550/560 transistors, the circuit will generate . You need to add capacitors C9 and C10 - as shown in the photo .
Please explain why! Thanks
Hello !Hello Tell me how to adjust low and high frequencies in the diagram?
The frequency correction complies with the RIAA standard . And you don't need to configure anything there . Here is the measurement of the NA-322 board -
Because the BC550 /560 are different from the original ZTX transistors . Without correction capacitors, there can be high frequency generation in the circuit . I had it like that .Please explain why! Thanks
- Analogue Source
- Naim NA322 MM phono board
