RIAA circuit help needed
RIAA circuit help needed Please consider donating to help us continue to serve you.
Old 15th January 2020, 11:13 AM   #81
Bonsai is online now Bonsai  Europe
Bonsai's Avatar
You just have to trawl through the specs Im afraid. The OPA1641 looks very good and for the money, the NE5534A is hard to beat.
FET input opamps usually have low input noise currents but the input noise voltage is higher as a consequence of the channel resistance - the lower the better. Bipolars have lower noise voltage but the noise current is higher.
Hopefully I’ll have time in the next week or so to finish the spread sheet and then you can just enter the data and make a direct comparison.
Old 15th January 2020, 11:22 AM   #82
Bonsai's Avatar
Originally Posted by DNi View Post
The new OPA828 fits the bill rather well, IMHO.
Braca
Yes, excellent opamp - very low noise voltage and negligible noise current.
http://www.ti.com/lit/ds/symlink/opa828.pdf
Old 15th January 2020, 12:41 PM   #83
ivanlukic is online now ivanlukic  Serbia
It's single opamp and would require new PCB design but the price is not that high, which is good. Digikey has it for about 7.50 dollars each.
The world has enough for every man's need, but not enough for every man's greed. Gandhi
Old 15th January 2020, 01:36 PM   #84
Bonsai's Avatar
I'm sure your current design will be ok Ivan.
Once you get to NE5534 levels of performance, the improvements above that are quite marginal IMV
Old 15th January 2020, 02:53 PM   #85
Vinyl has much more performance limitations than noise performance of opamps. For instance, how many turntable owners have tangential tonearms? One percent? Or less. That means that geometry will present big problem for 99% of owners. Depending on place of cartridge on the record surface distortions will be very high. Even if you have tangential tonearm who can guarantee that cantilever is ideally set in cartridge body or that needle is positioned ideally when glued in the factory? I've seen many times that people buy more expensive cartridge and get worse sound. That's because it is absolutely necessary to have ideally set geometry if you want to get the performance advantages of better polished diamond. How many users are able to set geometry ideally? Probably very few.
The charm of vinyl is not the charm of great specs. If great vinyl sound is the goal I am sure that my PCB with NJM2114 will suffice. For the perfectionist, nothing better than Bonsai's PCB with two NE5534 will be needed.
Old 15th January 2020, 03:17 PM   #86
First sentence from John Linsley Hood's "Valve and Transistor Amplifiers":
"An old friend of mine was in the habit of remarking that an engineer is someone who can do for five pounds what any damn fool can do for fifty."
That's what always guided me in the field of Audio. There must be some limit above which audio engineering becomes senseless and expensive mental acrobatics.
Old 15th January 2020, 08:28 PM   #87
rsavas is offline rsavas  Canada
SOIC8 footprint pads in Eagle are too long for that. It would be necessary to make new footprints with shorter pads and making new footprint is not an easy task for DIYer. Prasi could do it but question remains how difficult it would be to hand solder such footprint with shorter pads.
It is up to you if you want to do this, as it is your design after all, it was only a suggestion.
Did you rotate the SOIC-8, 90 degrees, that way it does not matter too much if the pads are longer.
Old 16th January 2020, 03:26 AM   #88
Mark Tillotson is online now Mark Tillotson
Actually its well worth going through tutorials on Eagle and learning to do footprints and devices, the pay-off is worth it.
I designed some SOIC8 breakouts a while back without the 90 degree turn - in practice you have to bend the legs a little to fit comfortably! Rotating means less than ideal routing of signals, not a big issue for audio stuff. You can place a decoupling cap on the underside of the breakout, note, in fact you can do footprints for both single and dual opamp decoupling.
Old 16th January 2020, 07:06 AM   #89
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by ivanlukic View Post
Is there any such opamp that has both very low input voltage and current noise? Usually, if one is very low the other is relatively high.
The free variable is device area.
A large area device can be designed for low hiss voltage. If it can also have high current gain, it can have low hiss current.
BJTs can be bought any size you want. Usually current gain is not critical and it is hard to maintain high gain all across a large device, so we have to be picky.
FETs have to be bigger for the same hiss voltage but input current hiss is very low (in our impedance range). There are a few fat FETs which can be great. Sadly they have gone out of style. The whole idea of JFETs is old, meaning the few new ones we can buy are 5-generation tail-end foundries who don't really care.
*Op*Amps* have to sell in the millions. Chip cost is really die area, how many chips you can get from a wafer. So chip (opamp) design uses SMALL devices. Some less-small than others.
The old-old LM394 was great. You paid a lot and got a modestly large area die, subdivided as 100 individual BJTs so each one could have very high current gain, and the sum had low hiss voltage. That's out of production though there is an equivalent now available from East Europe.
My own feeling is that the '5532 (0r 5534, or -A) will get you there without a any muss or fuss. The few-dB difference on paper vanishes when you drop the needle on the best vinyl. Yes, I know I can hear amp-hiss below surface scratch, but if the music is good it does not matter.
RIAA circuit help neededHide this!Advertise here!
Need better RIAA circuit for my phono amp. voycieck Tubes / Valves 4 4th August 2011 06:05 AM
Help With National RIAA Circuit ss007 Chip Amps 3 19th August 2010 06:32 PM
riaa circuit lt cdr data Solid State 42 27th April 2010 12:06 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
