Dual 1249 impresses
Dual 1249 impresses
Old 15th April 2019, 04:22 PM   #11
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Hi Peter,
did you observe the fin like main lever's plane which presses and moves the steuerpimpel ? There mustn't be any grease. Did you clean it?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 15th April 2019, 04:44 PM   #12
pjblakey is offline pjblakey  United States
Hello Kay...thanks for the response.
Yes, the textured surface of the main lever is clean. The steuerpimpel I used is quite a soft rubber. Maybe I will fabricate one from a little stiffer material such as the white core of coax cable.
When the tonearm makes the final 1/2” movement toward the spindle, it is very abrupt. Certainly not a slow sliding motion.
Peter
Old 15th April 2019, 05:08 PM   #13
Hi peter,
that's exactly how I do my steuerpimpels ! I cut 4 millimeters of the core isolation, so I have a cylinder of 4 mm diameter and 4 mm length. Then I drill 2 mm deep into the center, using a 2 mm bit. That's all, and these pimpels work perfectly!
Best regards!
Old 15th April 2019, 05:15 PM   #14
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Dual 1249 impresses
Dual 1249 was the first TT I ever bought! Crazy Eddies in the Bronx, right on Fordham Road! It didn't make it past my #1 son's teen years.
Old 15th April 2019, 05:53 PM   #15
The 1249 appears to be a fine player! It is Dual's biggest belt driven record changer and was only made in 1975 to celebrate their 75th anniversary.
Best regards!
Dual 1249 impressesHide this!Advertise here!
Dual 1249 AudioGeek Analogue Source 18 11th March 2017 07:13 PM
Who wants 2SK194 Dual Jfets, C3381/A1349 Gr dual pair BJT? Junm Swap Meet 0 28th October 2015 03:17 PM
Dual Othorn / Dual modified F215AN Build Log Summary Alethia123 Subwoofers 62 17th September 2014 12:59 PM
50VA Toroidal Transformer Dual Primary 120/120 and Dual Secondary 15/15 KatieandDad Swap Meet 3 11th February 2012 06:26 AM
Dual CV120 amp + Dual CL180 speakers Miguelxj Multi-Way 0 8th December 2011 11:17 PM
Copyright ©1999-2019 diyAudio
