Cartridge dynamic behaviour
Old 10th February 2019, 07:24 AM   #381
Hans Polak is offline Hans Polak  Netherlands
At last I've managed to reproducing Jackinnj's image.
First step was to reduce the Q significantly, while still keeping the phase going from +90 to -90degrees.
This was possible by splitting the Cap in two pieces and by adding a damping resistor.
See the LTspice model below and the sim |Z|=50*(Vin-Vout)/Vout.
From this I extracted Re and Im.
Treating the Imaginary values as being produced by a coil, I divided its absolute values by 2*Pi.
And voila, there it is, at the end quite a simple minimum phase model with just one SFR (self resonating frequency).
Hans
Old 10th February 2019, 08:29 AM   #382
luckythedog is offline luckythedog  United Kingdom
Hans
Well done, Hans. Although the system is minimum phase, phase plot and |Imag| don't match because that's not the system.
At small levels the challenge is to extract accurate phase info in this method. Also to know with confidence that |Imag| at 10kHz is inductive, which in this system it probably is.
Another method that might be easier at small signals is to examine |Real| at 10kHz. Thesis is that a loss mechanism would be involved in any apparent L reduction, which would show up in |Real|.
A philosophical thought: for a given flux change, does generator output follow |Imag|? I think it does.
LD
Old 10th February 2019, 09:06 AM   #383
I could make it even simpler, by just using one cap with a damping resistor in parallel, a somewhat more logical model.
This is as close as I can come to the original HP3577 image.
Hans
Old 10th February 2019, 09:59 AM   #384
Probably my latest model comes closer to the system.
That's how it seems to be.
Could it be that you mean |Z| instead of |Real|?
Zcart=Rload*(Vin-Vout)/(Vout).
Up to 30Khz L calculated from |Z| by dividing it by 2Pi*Freq gives almost the same outcome as when calculated from the true Imaginary.
At 10Khz they are within 1% in my model.
So do I, but at 10Khz also |Z|.
Hans
Old 10th February 2019, 01:04 PM   #385
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Is this helpful? Screenshot from HP3577, not Bode 100 -- -27dBm with 1Hz bandwidth, 16 averages and a long settling time, Z in of channels A and R 50R:
Old 10th February 2019, 01:09 PM   #386
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
That was my original point, the network analyzer is measuring transmission loss the rest is maths. If you look at that, due to the loss because of the impedance levels, the signal at channel A is VERY small. At a ref level of -40dBm the signal level at A gets below -80dBm and the instrument specs don't support an accurate phase measurement at that level. The de-Qing in making the model fit probably lumps all loss mechanisms such as eddy current. If a proper sensitivity analysis was done using the specs of the instrument I would suspect that the extracted values have fairly wide error bars.
BTW your notation is confusing, |Imag|, is redundant unless mag is magnetic? In either case the magnitude alone is neither inductive nor capacitive you need the phase (imaginary part).
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 10th February 2019, 01:11 PM   #387
It would help even more to know the Magnitude of the Y axis for |Z|.
Hans
Old 10th February 2019, 01:20 PM   #388
Thanks, those are the levels I expected. Since you averaged I assume the lumpy phase at resonance is part of the instrument residual? BTW the Bode 100 supports Python so you have available some powerful (free) model fitting tools.
Old 10th February 2019, 01:25 PM   #389
There is no Z on this plot, it's the magnitude of A/R which enters and leaves resonance at 20dB/decade inductive in capacitive out. See post #361 at -27dBm the plots agree (without the damped Q). I can try to add that and see what I get.
Old 10th February 2019, 02:23 PM   #390
jackinnj's Avatar
Also on the Bode 100, left y-axis is magnitude of impedance, right y-axis phase. Anyone who wants can get the raw data (real and imaginary) by sending a PM. (I did a calibration before this run.)
Cartridge dynamic behaviourHide this!Advertise here!
PTC Behaviour jayam000 Solid State 11 4th May 2009 03:35 AM
F3 - LED behaviour Nicola Pass Labs 2 22nd August 2007 08:02 AM
Copyright ©1999-2019 diyAudio
