Cartridge dynamic behaviour
Old Yesterday, 09:48 PM   #1251
Hans Polak is offline Hans Polak  Netherlands
I'm still working on the measurement set up, but results for the AT150MLX are good enough to be translated into a replacement circuit and that's what I wanted to show already for eventual comments.
The first image below shows the replacement circuit, its FR through a 47k //150pF amp in blue and through a virt. gnd amp in green.
The latter also with an added 6usec filter in red.
The second image shows the measured data versus the simulated results.
Measured and simmed go from 360mH to 325mH, have peaks at 370mH, an Fres at 56kHz, where the modulus is 215K and a par. cap of 16pF.
The only small difference is that in the measured data the inductance rolls off slightly earlier, but for the rest everything is the same.
A bit surprisingly, the value of the part of the coil with the par. resistor comes quite precise, in this case 0.083mH.
Hans
Old Yesterday, 10:06 PM   #1252
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
It's been a long weekend so I may have missed something, but does it need as low an additional filter as you have added there? In current mode it looks pretty flat up to CD4 frequencies.
Really interesting measurement. Thank you again for sharing.
Cartridge dynamic behaviourHide this!Advertise here!
PTC Behaviour jayam000 Solid State 11 4th May 2009 03:35 AM
F3 - LED behaviour Nicola Pass Labs 2 22nd August 2007 08:02 AM
Copyright ©1999-2019 diyAudio
