Teres platter options
Old 14th September 2018, 08:27 PM   #71
Seth Hensel is offline Seth Hensel  United States
Doing the math, (dont have a capable scale) I’m very close to 35 lbs right now with no shot. The copper platen alone is 11.235 lbs
Old 14th September 2018, 09:10 PM   #72
TomWh is offline TomWh  United States
You do have the copper top. How thick is the platter? The outside is most important. Not sure hole size, how many, and how deep. How much does weigh now?
You should be able to do the math for a close total weight. Subtract the removed aluminum weight then add the lead weight and your home.
Tom
Old 14th September 2018, 09:56 PM   #73
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Not sure about the proper english word or name, but there used to be something we locally call "lead sand" - used in chem labs for ballast weighting... ??
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 14th September 2018, 11:52 PM   #74
Hey Seth are the holes already drilled? If they are you could put lead shot in plastic bag and fill hole. Then pull it out and weight it, then multiply. This would save you the time of figuring volume. Forgot how much Chris said the bearing/ ball pad can take.
Tom
Old 15th September 2018, 12:14 AM   #75
Oh yes. The holes are machined. I’d post pics but its such a pain on this platform. We used to have a gallery one could link to but apparently that’s gone. I in fact did the maths on the weight. How i got to 35 lbs +- a couple of ounces
Old 15th September 2018, 01:06 AM   #76
For pictures hit advanced post at bottom then hit attachments. Then hit top one should bring up camera Docs etc.
Old 15th September 2018, 01:22 AM   #77
The holes are 2.00 inches x 2.25 inches deep
Old 15th September 2018, 09:10 PM   #78
InSides is offline InSides
Wow. Looks excellent. Remember to lift with your knees when picking up the platter.
Any avenues on surface finish? I take it the copper will tarnish over time?
Old 15th September 2018, 09:17 PM   #79
I was advised to use latex gloves when handling the copper platen. Once it is bonded to the aluminum it will be lacquered it I think. Per TomWh I will be using a mat.
Old 15th September 2018, 09:35 PM   #80
Interesting.
I have been struggling with finishing options - my approach uses a combination of POM (Delrin) and Aluminium. Delrin is relatively easy to clean using isopropyl, but the aluminium platter, even when anodized, can sometimes "stain".
It turns out that the bearing oil I've found most success with (in my approach) is slightly alkaline, and that dissolves the oxide layer causing the "staining". Apparently I have trouble wiping the oil from my fingers before handling the platter.
Lacquering would be an interesting approach, but won't that chip?
Teres platter optionsHide this!Advertise here!
TT Parts - Teres platter/motor, Maplenoll Bearing dwk123 Swap Meet 8 25th June 2010 02:39 PM
Drawing for machining platter to fit teres bearing 3GGG Analogue Source 2 30th April 2010 02:10 AM
need Teres platter diameter directdriver Analogue Source 10 21st July 2009 08:59 PM
Teres platter and bearing randytsuch Swap Meet 3 26th September 2007 03:35 AM
FS: New Teres Turntable Platter and Bearing Assembly jdubs Swap Meet 0 23rd October 2004 09:22 PM
