Sota Sapphire Disassembly
Old 24th June 2020, 03:42 PM   #11
AVWERK is offline AVWERK  United States
AVWERK's Avatar
I had one that was rubbing and adjusting the play at the screw got rid of the noise.
It had double the end play of 2 other SOTAs I also have.
I would try the screw adjustment first and if that doesn’t work, taking it apart as suggested
is the final step.
David
Old 8th July 2020, 02:32 PM   #12
mabrooks12 is offline mabrooks12
Default Sota Sapphire rebuild.
New motors are readily available directly from HURST. Just go to their website and punch in the part number from your current motor. I just ordered one and currently rebuilding my Sota GEM. This was the first turntable model ever made by Sota, it preceded the Sapphire!
Old 9th July 2020, 12:19 PM   #13
Default Sota GEM bearing
Attached is the Sota GEM bearing assembly
  Reply to this post
Sota Sapphire DisassemblyHide this!Advertise here!
Sota Sapphire rebuild and motor issues fmjunkie Analogue Source 13 24th February 2019 12:20 AM
Anyone built a new subframe for a Sota Sapphire? bigerik Analogue Source 2 17th August 2014 03:48 PM
Potentiometer disassembly help Gibraltar Parts 9 12th May 2013 03:21 AM
Help! cdm-9 disassembly dewdrop Digital Source 1 29th September 2010 01:40 PM
Sapphire speakers bonsai171 Multi-Way 3 24th August 2004 10:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
