Klimo MM/MC Phono RIAA Head Amp Model "LAR" - Schematic wanted
Maybe a different model ?
Thank you. Unfortunately yes. The model "MERLIN" is a complete preamp - the RIAA-part is only made for MM cartridges.
Germany D KLIMO MERLIN ecc88 Valve Tube Preamp HiFi Preamplifier Assembled Board | eBay
In the model "LAR" (only a phono RIAA preamp without input selector and attenuator for volume control) is also integrated a MC step-up stage (i. e. an input for moving coil cartridges).
The tubes, which are in use here are "E88CC" (two pcs/each channel) and 12AT7 one pcs/each channel).
Bit late. But this appears to give the signal circuit, but not the power supply:
German D.Klimo LAR Gold Plus Tube MM/MC Phono Stage Pre-Amplifier Board DIY Kit | eBay
Curious about it myself. You can purchase either just the boards, part kit or full kit. s-l400.jpeg s-l400%20(1).jpeg
I´have completed my phono stage last week and now I am hearing with it. Actual with ortofon kontrapunkt. It sounds very good.In my opinion a bit better than my phono mopped or my ear 834p diy built. In compare to my accuphase phono stage there is a bit more noise. But it is more theoretical. The amplifiying is about 70dB - very high -in mc mode.
I am just finishing a Klimo LAR phono amp. In the audio board there is a slot labeled “pf”. I am guessing that is for a loading resistor. Can anyone confirm. Also, is the loading just for the MM or also the MC? I am new at this and would appreciate guidance. Thx.
Without seeing the board, my guess is cartridge loading cap, hence "pf".
I am hoping to revive this thread because I am very intrigued by this DIY kit. I really want to buy and assemble it, but need to find someone who knows how to select and properly connect the power transformer to it. I live in the US and require the 110V as input.
For the rest of the assembly I would hope to get by with the pictures I've been able to collect and maybe use the schematic that's been posted here, although I don't think it's complete and matches the version I am looking to build.
Just so you know, there are two versions of this kit available. The first uses two transistor-based power supplies for each channel board. This seems to be a variation, because the original D.Klimo LAR Gold Plus also has tubes in its power supply and it uses one power supply board for the two channels. 99.9% of vendors online sell this version. There is only one I found who sells the design that most closely matches the original.
This is the vendor's page on Ali Express: D.Klimo famous machine LAR Gold Plus tube MM MC phono preamp phono turntable Preamplfieir 1:1 copy copy for high end audio|Amplifier| - AliExpress
In fact in this ad the vendor also has a link where one can buy the assembled form of these two versions, although they are too expensive for me (plus shipping cost is also very high).
I have a lot more pictures of this DIY kit as the vendor has been taking pictures for me from the already assembled version. I am hoping to simply copy what I'm seeing, but have to admit I do not understand the theory around the power transformer.
Can someone please guide me on what power transformer I'd need to buy to achieve 110V and how to connect it? I plan to document my assemble process and share it here to others can also realize this project themselves.
Thank you
So I'm sitting here with this kit almost finished and what I believe to be the correct transformer for it but am stumped (or stunned not sure which) as to the leads.
The transformer leads as follows, IN - 0V-115V BLK/RED and 0V-115V GRY/ORG. OUT - 0V-250V 0.1A YEL/YEL. - 0V-250V 0.1A GRN/GRN - 0V-8V 3A BLU/BLU GND Y/G
So would I be correct to connect up the 250-0-250 with the 0 being the GND lead? Therefor one board would be yellow-Y/G-yellow and the other would be green-Y/G-green? And for the low side connect the 2 Blue leads in parallel to the boards or one blue and one Y/G to each board?
Thanks, I am not looking to blow myself up! lol
Did you figure out the transformer secondaries configuration? Each channel needs a 250-0-250 and a 0-8V? So you need 5 wires for each channel?
I ran a quick sim in ltspice and it looks like a great performer. Only wonder how quiet the MC input would be, very difficult to implement a tube in that stage. Tempted to design a pcb but already have three tube phone preamps so I must resist :D
Besides my skills in pcb design are certainly lacking :)
