Turntable speed stabilty
Old 11th September 2019, 07:11 PM   #1101
ThomasA is offline ThomasA  Sweden
Thanks,
this is Python? I have OSX so any chance to get the script to work?
Thomas
Old 11th September 2019, 08:46 PM   #1102
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
Thanks Karl,
@Thomas: OSX is BSD under the surface so would be very suprised if there isn't a python package for it. like Python Releases for Mac OS X | Python.org
Old 11th September 2019, 09:13 PM   #1103
Originally Posted by billshurv View Post
Thanks Karl,
Yes I should be able to run it somehow, perhaps via Terminal. I think that there is a package pre-installed. Unfortunately I have very limited knowledge of using command-line via Terminal except for some basic commands. I used to know more, but that was a long time ago.
Old 11th September 2019, 09:59 PM   #1104
I've played around with Python 3.7.4 /IDLE and managed some things, but I have very little knowledge about this. Changed home dir, and inserted the name of test file to run. Appears to need/import some other modules?
from scipy import signal
ModuleNotFoundError: No module named 'scipy'
Old 11th September 2019, 10:00 PM   #1105
billshurv's Avatar
yes you will need scipy and numpy libraries, which should be a simple download.
Old 11th September 2019, 10:01 PM   #1106
OK thanks, I look around for that!
Old 12th September 2019, 12:43 AM   #1107
JP is online now JP  United States
JP's Avatar
Code:
sudo pip install scipy numpy matplotlib
"Show me on the doll where the aliens touched you." - SY
Turntable speed stabiltyHide this!Advertise here!
Modifying turntable speed AlexanderN Analogue Source 11 25th October 2016 01:26 AM
Turntable speed question........ JoeDJ Analogue Source 21 28th December 2013 06:29 PM
Turntable speed billone Analogue Source 7 13th February 2012 06:20 AM
Turntable speed under load YNWOAN Analogue Source 6 5th April 2008 11:01 AM
Turntable speed diyman Analogue Source 3 23rd May 2005 06:44 PM
Copyright ©1999-2019 diyAudio
