Turntable speed stabilty
Old 10th July 2017, 08:42 AM   #101
luckythedog is offline luckythedog  United Kingdom
Originally Posted by gpapag View Post
When time allows, can you post please the polar plot for the HFN S2 T3 as well.
Thank you again.
George
Sure - I had meant to post the polar plot for sections of that track, with vertical only stimulus, but there's so many interesting things going on the forum right now, I got distracted !
Anyways, here it is. Very interesting too.
The first polar plot attached below is for the section of the sweep near 8Hz, for direct comparison to the S2T2 (lateral stimulus) plot posted previously. The plot is somewhat similar, but has notable spectral content near 18Hz that isn't prominent in the lateral stimulus test
So I looked at the section of the S2T3 (vertical stimulus) sweep near 18Hz, shown in the second plot attached below. One can see what appears to be a pronounced resonant response in FM, nearly monotonic (looks like a bit of 2nd harmonic near 36Hz). FM due to headshell motion seems near certain as the explanation IMO.
Interesting, and very pretty ! It tallies with the classic spectral plots, IMO.
LD
File Type: jpg JVC QL-A2 M97xE HFNS2T3 8Hz stimulus.JPG (235.1 KB, 237 views)
File Type: jpg JVC QL-A2 M97xE HFN S2T3 18Hz stimulus.jpg (260.4 KB, 231 views)
Old 10th July 2017, 09:06 AM   #102
davidsrsb is offline davidsrsb  Malaysia
The lateral signal is so much less that it could even be down to channel imbalance.
I suppose real cartridges have very different horizontal and vertical compliance.
Old 10th July 2017, 09:33 AM   #103
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
This is a good question. There is at least one cartridge (the ortofon DJ S-120) that makes a marketing point of different compliance. And according to Walton, back in the 60s you had about half the vertical compliance to horizontal. Now, with a donut elastomer its only the suspension string (if you have one) which modifies the vertical compliance. Unsure how to model that though...
Old 10th July 2017, 09:45 AM   #104
In FM, which is what is at issue for pitch stability, channel balance makes no difference to performance or measurement. L, R, mono, difference, all show identical FM results because it's just the relative linear velocity of stylus to groove that matters.
The difference observed here is due to mechanical stimulus to headshell motion being vertical in the case of S2T3 recorded file and lateral in the case of S2T2.
What makes for the difference here is the direction of headshell motion in response to direction of mechanical stimulus.
LD
Old 10th July 2017, 11:18 AM   #105
Hiten is offline Hiten  India
Can anyone answer my query ? When you people speak of headshell movement. Do you mean movements at headshell end or at bearing end. Looks like Tonearm with unibody like Rega would be good choice if movements is at headshell end.
Regards.
Old 10th July 2017, 11:35 AM   #106
billshurv's Avatar
At resonance things are not as stiff as they seem
https://www.youtube.com/watch?v=j-zczJXSxnw The tacoma narrows bridge.
Old 10th July 2017, 11:42 AM   #107
gpapag is offline gpapag  Greece
gpapag's Avatar
Movement at headshell.
A friend has a Rega 3. I may pick it up for a test run.
Thank you Lucky.
This becomes very tempting to try the longhorn mod.
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 10th July 2017, 08:19 PM   #108
Charlie S is offline Charlie S  United States
Cantilever suspension in Shure cartridges comprises a combination of an elastomeric donut between the magnet and the metal stylus housing, along with a metal support wire. From visual inspection, the cross-section shape of the housing and magnet (and thus elastomer) appears* to be very slightly rhombic, not a perfect square, with vertices aligned lateral and vertical. Thus, unequal compliance and damping in the lateral and vertical directions appears likely. In addition, the geometry of the tie wire appears intended to primarily provide vertical support, and will limit vertical compliance.
It seems reasonable to limit vertical compliance in order to raise stylus-arm resonance well above subsonic record warp frequencies. For several practical reasons, it is standard practice to mix program material to mono at lower frequencies when cutting a disc master. So there is limited vertical musical program to excite a LF resonance. Thus, limiting vertical compliance to raise the vertical resonance frequency makes engineering sense.
* These observations are purely from eyeball and drawings in promotional literature. We’d need a few sacrificial styli and calipers to confirm.
Old 10th July 2017, 09:08 PM   #109
gpapag's Avatar
Shure M97xE
George
Old 11th July 2017, 04:52 AM   #110
Thanks Bill and gpapag.
That would be very interesting to see the difference. Your efforts and also other contributors explaining this stuff is very much appreciated.
Regards.
Turntable speed stabiltyHide this!Advertise here!
Modifying turntable speed AlexanderN Analogue Source 11 25th October 2016 01:26 AM
Turntable speed question........ JoeDJ Analogue Source 21 28th December 2013 06:29 PM
Turntable speed billone Analogue Source 7 13th February 2012 06:20 AM
Turntable speed under load YNWOAN Analogue Source 6 5th April 2008 11:01 AM
Turntable speed diyman Analogue Source 3 23rd May 2005 06:44 PM
Copyright ©1999-2019 diyAudio
