A simplified universal differential or single ended phono preamp
Old 6th April 2017, 04:28 PM   #11
DPH is online now DPH  United States
Originally Posted by scott wurcer View Post
still no 7th's
Pity, sometimes a minor seventh really helps a chord out.
Nice to hear it's well-behaved into overload conditions. Or, well, see.
Happy DIYing, Daniel
Old 6th April 2017, 08:36 PM   #12
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by RNMarsh View Post
What is the CMR vs freq and the +/- PSRR vs freq?
THx-RNMarsh
CMRR was -86dB at 1kHz, pretty much follows the RIAA curve so I would say fairly constant with frequency. I was scared for a minute because I am using two channels of a sound card to make a true differential input and when I set the phase to 0 the CMRR didn't look so good. The DAC's turn out to have 0.5% gain mismatch, had to short the inputs and use one DAC.
I removed the bypassing and nothing oscillates so I was thinking I would try to measure PSRR by putting an old output transformer backwards to inject some AC in series with the supply with the 4 Ohm tap. Anyone try this before?
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 6th April 2017, 08:55 PM   #13
john curl is offline john curl  United States
john curl's Avatar
About 7th harmonic:
"Condemnation without Examination is Prejudice"
Old 6th April 2017, 09:02 PM   #14
john curl's Avatar
Congratulations Scott, you finally found the audio usefulness of using all fet designs! Can't make 7th harmonic? Good!
Old 6th April 2017, 10:18 PM   #15
gerhard is online now gerhard  Germany
gerhard's Avatar
I have made a box/little board with 2 BB/TI BUF634( 5pin-TO220) for Vcc/vee + noise / sweeper input but never really used it at all. Seriously, I need more time.
And I insist that the raw supplies are reasonably clean; if someone needs 110 dB PSSR
that means that he already has all the dirt on his board.
cheers, Gerhard
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
Old 6th April 2017, 11:29 PM   #16
That's what we do with VI's in the testers, looking to avoid building something I will never use again. I had a tech once that floated a whole Kronhite but made a miss-connection that let lots of magic smoke out.
Old 7th April 2017, 12:35 AM   #17
gerhard's Avatar
Hey, I once worked for Verigy (ex HP) and I had a medium sized mixed signal tester just for my work; I was the only user, including somewhere an AP 2732(?, like an early eprom) which was a major PITA in the system and was floated. They needed someone who understood Unix/Linux drivers as well as TDR ... For me, it was too software-centric in the long run. Especially if they had the newest 50 GHz VNAs in the next cubicle and I had to ignore them. Yes, more than one or two.
Old 7th April 2017, 06:08 PM   #18
EUVL is offline EUVL  Europe
Almost missed the post of Scott's RIAA.
Thanks for sharing with us, and look forward to a high(er) gain version before too long.
Best regards,
Patrick
xen-audio.com
Old 7th April 2017, 06:42 PM   #19
Using the same philosophy you might need 6DJ8's at the input rather than JFET's. The gain structure for open-loop amplifiers is a difficult trade-off unless you punt the THD and say -60db is fine or something like that.
OTOH I have a third board and lots of FET's from Paul Norton there might be a sweet spot with an LSK389 and more bias current to get the 14dB of gain back.
Old 7th April 2017, 06:50 PM   #20
Remember the spice files I sent you a while ago for the version with 300x gain at 1kHz ?
In spice at least, THD is quite decent at 2Vrms out, using 4x 2SK372 at the input.
Maybe you would have another look at see if I have done something really silly......
Patrick
xen-audio.com
A simplified universal differential or single ended phono preampHide this!Advertise here!
Differential to single ended recommendation (PCM179x) sfasf Digital Line Level 20 20th March 2013 01:11 AM
single-ended to differential? gentlevoice Digital Line Level 16 17th December 2008 06:18 AM
testing a single ended or differential topology Stefanoo Pass Labs 11 26th October 2007 05:59 PM
Converting from single ended parafeed to differential dsavitsk Tubes / Valves 9 12th July 2007 06:46 PM
Differential to single ended... Bas Horneman Tubes / Valves 21 2nd April 2003 02:05 PM
