Sonic Frontiers SFP-1 Sudden Noise on MC Input
Old 4th November 2018, 07:00 PM   #11
ralphfcooke is offline ralphfcooke  United Kingdom
Not sure what other component changes would have to be made, but the lsk170 is often chosen for low noise front ends.
Old 16th January 2019, 07:53 PM   #12
artosalo is offline artosalo  Finland
artosalo's Avatar
I am repairing Sonic Frontier Phono 1 from year 1997 and looking for the schematics.
I have noticed the schematics from the earlier discussions, but these seem to be from 1993 and are different.
Most urgently I need the schematics of the power supplies, so if anyone have, I would be grateful.
Old 17th January 2019, 04:02 AM   #13
Boydk is offline Boydk  Denmark
Was wondering. When you switch between MC and MM (the cathode resistors)... I presume this is done by a relay...... Could it be something as stupid as a bad contact in the relay/switch????
Old 17th January 2019, 05:05 AM   #14
ticknpop is offline ticknpop  Canada
There is a resistor from the high voltage supply dropping down the voltage to the drain of 310 , thats a likely suspect.
The later SF phono stage used the quieter 2 sk147 in an epoxy cylibnder to cut down thermal drift.
Sonic Frontiers SFP-1 Sudden Noise on MC InputHide this!Advertise here!
Sonic Frontiers SFP-1 Phono Stage Jebem Tubes / Valves 14 4th January 2019 02:06 PM
Sonic Frontiers SFP-1 Jempie Analogue Source 20 4th May 2018 04:08 PM
Sonic Frontiers SFP Jempie Analogue Source 0 9th January 2016 01:33 PM
Sonic Frontiers SFP-1 mods? rdf Tubes / Valves 6 24th December 2009 07:36 AM
Sonic Frontiers Jitterbug eleakist Digital Source 2 11th February 2008 05:23 PM
Copyright ©1999-2019 diyAudio
