changing speed potentiometers,pioneer tt
See if you can get the specs, hifiengine or vinylengine.
The pot does not look like it a high powered pot, based on the numbers it looks to be a 500 ohm pot.
Trying to find a pot that would be physically equivalent might pose a problem.
Look at standard sources like Mouser,Dig-key,Farnell etc.
Try cleaning the pot first with Deoxit fader lube
