Digital Tachometer for record player (LCD display)
Old 12th February 2019, 04:13 PM   #371
tauro0221 is offline tauro0221  United States
He can open the text file copy it and then open the Arduino IDE window and paste it in the IDE window then save it in the INO format..
Old 13th February 2019, 05:48 AM   #372
Rajkumar_ is offline Rajkumar_  India
I have changed "tacho.ino' but still I have problem with loading sketch file to Arduino Nano.
Old 13th February 2019, 05:52 AM   #373
alexandro is offline alexandro  Bulgaria
Default Digital Tachometer for record player (LCD display)
Can you please show us the error message?
The folder containing the .ino file must be the same name as the name of the file. In your case the folder name should be “tacho”.
Old 13th February 2019, 12:28 PM   #374
Pyramid is offline Pyramid  United States
Pyramid's Avatar
Verify that you have "Arduino Nano" selected as the device under menu item Tools/Board.
Old Yesterday, 08:12 AM   #375
Thank you for all, when very file sketch show message "Compiling File Done" when loading file having message "loading Problem" I have suspect board having problem! Earlier I have same experience on Arduino Uno then replaced board solve problem.
Yes I have selected "Arduino Nano" installed driver and selected com port. Thanks Rajkumar
Old Yesterday, 09:40 PM   #376
raymondo is offline raymondo  United Kingdom
Just want to say thanks again for sharing this. It helped me confirm a suspicion that my speed was drifting a little . You could hear it on sustained notes . Readings would vary from 33.22 to 33.45 or so in a seemingly periodic fashion. Strip down and clean of everything and oiling the motor has now got it perfect. Only the last digit bobbles a bit say 0.002 each way . Without this tool I would never have managed to correct this for certain. Tremendous.
Digital Tachometer for record player (LCD display)Hide this!Advertise here!
Digital Turntable Tachometer and DDS based PSU Pyramid Vendor's Bazaar 234 6th November 2017 01:57 AM
The new £5-Record-Player.... M_Balou The Lounge 5 18th October 2016 11:38 PM
Old record player Rucyrius Everything Else 0 24th March 2011 03:35 PM
Change old cd player display to LCD, easy? Tubeee Digital Source 0 7th December 2003 12:03 PM
Copyright ©1999-2019 diyAudio
