Digital Tachometer for record player (LCD display)
Old 8th February 2019, 03:06 PM   #361
raymondo is offline raymondo  United Kingdom
Originally Posted by Pyramid View Post
It should display the title on the top line of the LCD and "RPM: --.---" on the bottom line.
Does the tach sketch use the same LCD initialization and configuration commands as your Hello World sketch?
i've attached the sketch hopefully
probably easier than me relaying the information
thanks
Old 8th February 2019, 05:00 PM   #362
Pyramid is offline Pyramid  United States
Pyramid's Avatar
Please post the exact tach sketch you are using (there are quite a few floating around).
Old 8th February 2019, 05:17 PM   #363
attached
thanks
Old 8th February 2019, 05:45 PM   #364
Pyramid's Avatar
You are mixing libraries and function calls into them. If your LCD has a PCF8754 or PCF8754A I2C chip, you should be able to use the tach scketch as it was originally written:
#include <LiquidCrystal_PCF8574.h>
LiquidCrystal_PCF8574 lcd(0x27);
The function calls in the void setup() will then be correct.
If you are going to use your library:
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);
Then you need to replace:
lcd.begin(16,2) ;
with
lcd(init);
The syntax for function calls between the two libraries may differ for the other commands:
lcd.createChar(0,DISC);
lcd.home();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Arduino Uno Tach");
lcd.setCursor(0,1);
lcd.print("RPM: --.---");
lcd.setBacklight(255);
You will have to look at the on-line reference for LiquidCrystal_I2C.h and translate if necessary.
Probably easiest to get your module working with LiquidCrystal_PCF8574.h if possible.
Old 8th February 2019, 06:17 PM   #365
lcd.begin(16,2) ;
with
lcd(init);
lcd.home();
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
Its now working - thanks Bill - time to build the sensor !
Old 11th February 2019, 11:47 AM   #366
lcd.begin(16,2) ;
with
lcd(init);
lcd.home();
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
This is now working perfectly - many thanks for your help Bill - i'd buy you a beer if you were not 5000 miles away !
I've set the CALIBRATE value to 1873680 as pin 2 measured 15.614KHz using my fluke (which is very accurate)
I take it that's right ?
Thanks again - collaboration on here is better than with my global work colleagues :-)
Old 11th February 2019, 12:32 PM   #367
Pyramid's Avatar
That should be correct.
Old 12th February 2019, 06:46 AM   #368
Rajkumar_ is offline Rajkumar_  India
Hi Bill, I have try to connect Arduino Nano V3 with Serial module LCD 1602 16X2, I was try to uploading sketch file tahco.txt which one used on Arduino Uno, not able to loading file. Is it there any other sketch file required for Nano? Thanks Rajkumar
Old 12th February 2019, 01:05 PM   #369
Pyramid's Avatar
I've not used a Nano. Maybe someone else has done this?
Old 12th February 2019, 01:09 PM   #370
alexandro is offline alexandro  Bulgaria
Hi Rajkumar,
Have you renamed the .txt file to .ino?
You cannot load a .txt sketch to Arduino IDE.
Please try to rename the file extension and load it again to the program.
Hope that helps.
Digital Tachometer for record player (LCD display)Hide this!Advertise here!
Digital Turntable Tachometer and DDS based PSU Pyramid Vendor's Bazaar 234 6th November 2017 01:57 AM
The new Ģ5-Record-Player.... M_Balou The Lounge 5 18th October 2016 11:38 PM
Old record player Rucyrius Everything Else 0 24th March 2011 03:35 PM
Change old cd player display to LCD, easy? Tubeee Digital Source 0 7th December 2003 12:03 PM
Copyright ©1999-2019 diyAudio
