Refurbishing my old Diy Turntable
Hello I am new on this forum. I have this DIY Turntable I build 30 years ago. Then I moved a view times and it vanished in a box. Now I want to rebuild it up again and make some changes. Not so much in the design more technical like magnetic bearing and change the motor. I used an Thorens synchronous motor which was far too weak. Last weekend I put the parts out of the box measured them and mad some CAD models. Her is what I came up with and I hope my old turntable will look similar to this when I am ready with the project. I can take some pics of the status quo if interested. Hope I get some feedback and advice from you.
Refurbishing has startet
Some pics of parts
Looks gorgeous! Looking forward to seeing the completed new one. Good luck!:)
Hei, thank you all for replying. My plater is about 5 kg in comparison to 1.5 kg the platter of an Thorens. It needed always a helping hand for getting the rotation started. I am going for an BLDC solution. I thought about buying the motor from Jasmin Audio, because i take me to long research to come to solution. But i build my own housing around it. Hilsen Joschi
New Pics
I am getting closer. Have some problems with testing lubrication for the bearing. Found very different opinons in forums, was not very helpfull:confused: Will do some more tests the next days. Magnetic vertical bearing works fine.
Still a lot to do!
Jochen
Since I am the nearly the only one who replied on my thread it make no sense for me to go on with it. In the beginning I thought it might be an interesting project not just for me, since this is a diy forum. It's not that I am dissapointed, because I had wrong expectation. It is just boring to answer your own thread.
