Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Community
What is the ideal conventional rumble filter?- Douglas Self
Thread Tools
Old 14th March 2016, 05:01 PM   #1
DouglasSelf is offline DouglasSelf  United Kingdom
DouglasSelf's Avatar
Default What is the ideal conventional rumble filter?- Douglas Self
Those of you with an interest in vinyl may be aware of the long thread on rumble filtering by removing subsonic anti-phase information (from vertical stylus movements) that has been running at:
http://www.diyaudio.com/forums/analo...s-self-81.html
This has so far resulted in an article to be published in Jan Didden's Linear Audio in April, and a planned talk at the AES convention in Paris this June. Hopefully a PCB is going to be produced.
In the course of doing this, it struck me that very little seems to have been written about conventional subsonic/rumble filters, unless I've missed it. I would be glad to hear of any articles or papers you know about, and very interested to hear what people think is the ideal conventional rumble filter response.
I have a few ideas on this myself, but what do you think?
Douglas Self
Old 14th March 2016, 05:36 PM   #2
Jenyok is offline Jenyok  Russian Federation
Super deRumble filter.
See circuits.
Old 14th March 2016, 05:54 PM   #3
The Derumbleizer cancels rumble 3 octaves higher than any filter
Good article.
Old 14th March 2016, 06:07 PM   #4
bulgin is offline bulgin  South Africa
Pardon my ignorance. I have been reading through diyaudio member montypig78's thread but most of it is way above my comprehension.
If I read correctly, the rumble and its proposed 'alleviator' schematics refer both to vinyl lps/vinyl 78's and 78rpm shellac records.
My naive question - is the rumble turntable or cartridge and tonearm related?
I play both vinyl and 78rpm shellac records and use Garrard 301's and Micro/Micro Seiki turntables.
bulgin
Old 15th March 2016, 03:37 PM   #5
Originally Posted by Jenyok View Post
Not an article, but an advertisement.
There seems to be something amiss with the graph labelled
"Frequency response for signals applied to this channel only."
with frequency response deviations up to 400 Hz.
But this is all Off Topic. This thread is intended to canvass opinion on conventional rumble-filters- ie just filters, one per channel, with no crossfeeding or antiphase cancellation.
Douglas Self
Old 15th March 2016, 05:31 PM   #6
mjf is offline mjf  Austria
the only schematic i have with a rumble filter at the input.........but i have never built it.
Old 16th March 2016, 05:19 PM   #7
This looks like an idea put forward by Tomlinson Holman in the 80's. I've never tried it either- I would be nervous that the noise performance would be impaired, and those relatively small caps at the input would make the circuitry after them very susceptible to capacitive pickup of hum etc.
'flankensteilheit' means 'edge steepness' which I assume is the rolloff slope, but I don't see how it could ever be 25 dB/octave. Could be a typo for 24dB/octave, of course, but the circuit looks like a second-order filter to me, which would give only 12dB/octave. There could be some subtle interactions with C4,C5 and C9 that yield 24dB/octave; a quick sim would answer that but for the reasons above this doesn't look like a promising path to explore.
Douglas Self
Old 16th March 2016, 05:41 PM   #8
Bigun is offline Bigun  Canada
Bigun's Avatar
do transformer inputs provide a natural rumble filter due to roll-off of transformer response?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 16th March 2016, 05:54 PM   #9
bulgin
My understanding is that with a half-decent turntable almost all the subsonic rubbish comes from disc warps, usually amplified by the cartridge/arm resonance . (say 8 -12 Hz) I very much doubt if 100kg platters do any good at all.
Douglas Self
Old 16th March 2016, 07:23 PM   #10
rif is offline rif  United States
Not a cowbow
rif's Avatar
I'm quite ignorant of these things - are they also called infrasonic filters? That's what I found in a brief search of the Apt Holman service manual. If it's on topic, I can try to post the relevant sections.
What is the ideal conventional rumble filter?- Douglas SelfHide this!Advertise here!
The ultimate rumble filter - far more effective than just a high pass filter! monty78pig Analogue Source 178 15th May 2020 02:09 PM
Rumble filter LAJ Music 0 24th November 2010 05:08 PM
Rumble Filter soloxp Subwoofers 5 27th July 2006 12:02 PM
Implementing a Rumble Filter before the Amp? Bogie Subwoofers 12 2nd January 2006 10:48 PM
Passive Rumble filter? fortyquid Multi-Way 5 30th November 2003 12:25 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
