Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Community
lm4562 MM phonostage on solar energy.
Thread Tools
Old 15th May 2015, 09:10 PM   #1
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Default lm4562 MM phonostage on solar energy.
Below my solidstate phono stage. Runs of NiMH accu charged with solar energy.
No noise or humm, RIAA within 0,5db. with impedance input selector. Adjustable amplication factor. Easy to build.
Old 15th May 2015, 09:13 PM   #2
Koifarm's Avatar
Link for PCB.
http://www.monstercore.nl/phono3%20-%20PCB.pdf
Old 15th May 2015, 09:13 PM   #3
Koifarm's Avatar
In euro case.
Old 15th May 2015, 09:14 PM   #4
Koifarm's Avatar
The inside.
Old 16th May 2015, 08:45 PM   #5
madis64 is offline madis64  Estonia
Most interesting solution, thanks for sharing.
One recommendation for improvement though - the dipswitches should be accessible without opening any covers - changing cartridges and adjusting the input setup should be performed without screwdrivers.
  Reply to this post
lm4562 MM phonostage on solar energy.Hide this!Advertise here!
Rock/Pop Music Enhances Solar Cell Energy Production Magz Everything Else 1 7th November 2013 06:15 PM
phonostage problem. murphythecat8 Analogue Source 1 31st July 2011 03:55 AM
freaky new phonostage Vinylsavor Tubes / Valves 35 30th November 2010 07:30 AM
Pearl phonostage Mark777 Pass Labs 0 6th July 2003 11:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
