DIY Air Bearing Linear Arm
Old 29th July 2019, 03:08 PM   #441
nocdplz is offline nocdplz
nocdplz's Avatar
Condolences for your expensive loss, sincerely.
Many years ago, building a special 6x15 panoramic film camera for my work, I learned my lesson: I sent all the pieces to black anodizing, and then started to epoxy them together. Some detached without any warning. The anodiser explained that to make them shiny and durable they were Teflonized at the end of the process.
So use a bit of sand paper to find a moderately rough aluminum surface in the areas to be glued. It's not a matter of resin, usually, but of surfaces.
hope this helps - carlo
Old 30th July 2019, 02:34 PM   #442
super10018 is offline super10018  United States
Thanks everybody for your helps!
I went to Home Depot and bought a JB steel reinforced epoxy. I tried a small portion. It seems to me it is pretty good. For the parts of head shell, I made it myself, but this time, I am going to let someone who has all the equipments do it for me. So, the head shell will fit the bushing nicely and gets maximum contact area. I will also sand the contact area of the air bushing. Hopefully, all of this will solve the problem.
Jim
Old 30th July 2019, 03:16 PM   #443
nocdplz's Avatar
Hi jim. before sanding put a little drop of resin on the bushing and let it cure; then try to take away witn a stick. Black anodization is often hard anodization, that is with the pores well sealed and very slick, but not always with teflon. Acetone rinsing may be enough.
One of the strongest resin in my experience is UHU plus 24h - transparent (no fillers- no solvents). more speed = less resistance
ciao - carlo
DIY Air Bearing Linear ArmHide this!Advertise here!
DIY Air bearing tangent tone arm neil_kaye Analogue Source 160 12th October 2013 04:20 AM
DIY parallel tracker air arm - another one Speedysteve7 Analogue Source 36 30th May 2013 02:10 AM
HELP ZETA-ARM bearing GIPIONE Analogue Source 6 15th October 2009 12:20 PM
YAABA - yet another air bearing arm woodturner-fran Analogue Source 1 10th March 2009 12:24 AM
MG-1 AIR BEARING Tangential Arm audio-kraut Analogue Source 7 24th November 2004 08:55 PM
Copyright ©1999-2019 diyAudio
