Which OP in Clearaudio Basic
Old 8th October 2014, 06:56 PM   #11
Mooly's Avatar
I see you've already done the job
Old 8th October 2014, 07:04 PM   #12
arvid is offline arvid  Sweden
My friend beleive lightning was the case, yes.
Old 16th April 2019, 10:48 AM   #13
Celestial is offline Celestial  United Kingdom
Originally Posted by arvid View Post
Greetings.
I'm repairing a friend's Clearaudio Basic. One of the OPs needs to be replaced. The DIL-8 case is scrubbed and the label is unreadable. Does anyone know which OP is used in Clearaudio Basic?
Arvid
I realise it's been a while but, if you still have the dead opamp, you can heat the IC's plastic enclosure with a heat gun to 550 deg C and carefully remove the plastic encapsulant, use a pair side cutters to snip away from the edges, while holding it with long nose pliers.
Use a stand to grip and hold the heatgun in a fixed convenient position.
At the right temp, the case will split and reveal the silicon die - it's usually tiny around 3x3 mm or less. Under a 10x microscope you should be able to read the manufacturuer's part number on the silicon die:
TI (BB), Analog Devices, Nat Semi all put the part number on the die next/near to one of the pads for the power pins.
e.g. for the AD825 opamp, you'll see '825' on the die. For the TI OPA2134, they just put 'TI' '2134'. Similar NEC UPC324 is 'NEC' 'C324', PHILIPS/NXP is just 5534A for the NE5534AN. Also, you should see the vendor's logo on the die, 'AD' Analog Devices.
Make sure you have a respirator on when heating the plastic encapuslant - the fumes are toxic.
Also wear safety glasses and gloves.
As for the heat gun, I've used a Steinel HG 2320 ESD - that's what we have at work. The Steinel HG 2310 LCD is good too.
Use the low fan setting. Be patient, it takes about 20-40s of direct heat to get the IC's encapuslant soft enough to break-up gently and crumble.
Be cautious at first - practice on another chip if it helps.
Having been through the same hassle with another Clearaudio preamp and told to send it to Germany for repair - The opamp in my case was an LM4562 - the silicon die just had 'NS' and '4562' on it.
I don't know why they're so paranoid about giving the information; Sanding the name off a chip doesn't stop anyone in the end...
I know of companies in Romania and China where you can send the product to and for around USD500-1000 they'll come back with a complete verified schematic and details of all semiconductors, right down to transitor gains, you name it if you ask for it...and you're prepared to pay
Good luck!
Which OP in Clearaudio BasicHide this!Advertise here!
Clearaudio BASIC Service Manual wanted aire Analogue Source 3 2nd October 2014 02:20 PM
Basic op amp question Tube Noob Chip Amps 3 22nd November 2011 05:03 PM
Basic op amp optical compressor questions LarsXI Solid State 0 1st July 2008 11:32 PM
Clearaudio NANO mods tomstearns Analogue Source 1 10th November 2007 07:45 PM
Basic question about choosing op amps leadbelly Solid State 1 18th February 2004 08:21 PM
Copyright ©1999-2019 diyAudio
