The Incredible Technics SP-10 Thread
Old 15th June 2015, 06:12 PM   #671
user510 is offline user510
user510's Avatar
concur on the reading of 91.6deg.
Although I took a slightly different tack to get that figure. Visualizing geometry involves a perspective unless one is born with perfect geometric perception.
My method:
(124.68deg) - (58.53) = 66.15
66.15 / 2 = 33.075
58.53 + 33.075 = 91.605
my way is longer but it helped me to visualize that I was measuring from tonearm side.
anyway, the microscope pics look great. You must be quite close to the optimal SRA. Although listening to well known records helps to confirm the adjustment.
Cool setup.
-Steve
Old 16th June 2015, 01:46 PM   #672
reddish75 is offline reddish75  United Kingdom
Pretty much finished restoring my SP10, recapped and faulty phase drive transistors replaced, this was a p/l version but I managed to get my hands on a regular logic board to restore start/stop easily.
Trouble I'm trying to crudely set the speeds but 33 and 45 rpm wont set on the strobe, its nearly there but its still moving, the pot wont adjust anymore, 78rpm is rock solid.
Could anyone help me with where to look?
Old 16th June 2015, 02:16 PM   #673
JP is offline JP  United States
JP's Avatar
MKII or 2A? You need an oscilloscope to align the PLL - no way around that.
"Show me on the doll where the aliens touched you." - SY
Old 16th June 2015, 02:31 PM   #674
It's a mk11, I know I need a scope to set it properly but surely it should be settable by eye using the strobe as well?
Old 16th June 2015, 03:02 PM   #675
6L6 is offline 6L6  United States
6L6's Avatar
That's not how it was designed.
The service manual is available at Vinyl Engine, download it. There are a few capacitors you need to replace, see post #29 -- The Incredible Technics SP-10 Thread
Old 16th June 2015, 03:52 PM   #676
Yep, and I have the service manuals.
As I said it has been recapped unless theres some ploy caps that need replacing? Just wondering if the slight movement on the strobe was classed as normal at 33/45 rpm as well as the the inability to set it to 'still' as it is possible on 78rpm?
Old 16th June 2015, 04:23 PM   #677
JP's Avatar
Those pots do not set the speed, they align the PLL.
Old 20th June 2015, 01:10 AM   #678
Neilsan is offline Neilsan  New Zealand
Well,just finished replacing all the caps in my 10/2 and PS.One in the PS needed doing!
Now just have to get a friend to tune it for me.Then it should be good for another 30 years.See me out that's for sure!
Thanks for all the advice on this thread.
Old 20th June 2015, 06:41 PM   #679
JP's Avatar
Congrats! Let us know what you think when you get it set up.
Old 20th June 2015, 08:52 PM   #680
Notinthislifetime is offline Notinthislifetime  United Kingdom
Just got hold of my third 10/2, it has a problem though......switch the thing on and the platter spins fast....then faster......then faster still until it can be used as a drone. I've narrowed the problem down to the logic board 'cause when I fit the board from my 10/2PL it works albeit with no stop/start function. Is this one of the unrepairable ones or something that can be resurrected?
The Incredible Technics SP-10 ThreadHide this!Advertise here!
Technics SP 10 Speed Problems rollinr Analogue Source 29 27th October 2017 09:05 AM
Technics SP-10 Doesn't Spin breadhead Analogue Source 6 26th October 2014 11:09 PM
Cheap oscilloscope for setting up a Technics SP-10 johnm Analogue Source 22 28th June 2011 07:47 PM
Technics SP-10 speed problems Stefanoo Analogue Source 3 17th August 2008 10:05 PM
Technics SP-10 MKII pitch control peterb Analogue Source 6 28th March 2004 01:29 PM
Copyright ©1999-2019 diyAudio
