The Incredible Technics SP-10 Thread
Logic circuit board recapped 🍻
Reactions: 1 users
don't trust those indications, in the past I have found inconsistencies depending on the versions intended for export; rather check which capacitors are applied to your boards and replace capacitors of the same capacity, at most you can replace them with a higher voltage but the capacity must remain unchanged... and ask if you have any doubts.
Reactions: 1 user
I used few WIMA MKS2(red) and Panasonic ECQ(brown) polyester caps
I always consider it a good idea to use polyester or polypropylene capacitors than to use electrolytic capacitors as they are more performing and have better characteristics; unfortunately it is not always possible to use them because the dimensions beyond a certain capacity become important and it is not always possible to use them due to the limited space; therefore electrolytics due to their small size and high capacity become again indispensable.
