Ordered Panny FC for all values except 1uF/50V
that value (FC or FM) is no longer produced by Panasonic, you can find them from other brands for example Nichicon (for audio) always polarized or you use polypropylene like the Wima Mks which are just as good... or better
Yep.OK, didn't see those. But I expect most any decent electrolytic these days (Panasonic FR/FC...) would have at least as low an ESR as in the late 70s and 80s when these turntables were designed.
Logic circuit board recapped
don't trust those indications, in the past I have found inconsistencies depending on the versions intended for export; rather check which capacitors are applied to your boards and replace capacitors of the same capacity, at most you can replace them with a higher voltage but the capacity must remain unchanged... and ask if you have any doubts.
I used few WIMA MKS2(red) and Panasonic ECQ(brown) polyester caps
I always consider it a good idea to use polyester or polypropylene capacitors than to use electrolytic capacitors as they are more performing and have better characteristics; unfortunately it is not always possible to use them because the dimensions beyond a certain capacity become important and it is not always possible to use them due to the limited space; therefore electrolytics due to their small size and high capacity become again indispensable.
- Analogue Source
- The Incredible Technics SP-10 Thread
