The Incredible Technics SP-10 Thread
Old 5th October 2018, 09:10 PM   #1161
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Never understood why the SP-10 has no overvoltage protection at the input for its supplies. If something goes wrong with the external supply, it can generate well over spec voltage and fry the electronics. The supply fuses are of no help, by the time they blow, the table is gone... A recap of these old power supplies is a must, before connecting it to the table! I'll certainly install an overvoltage protection on the 5V digital supply. The others supplies goes to transistor/analog/power stage that will survive and incorrect supply, not the digital section with the 5V supply though!
Old 5th October 2018, 09:18 PM   #1162
BrianL is offline BrianL  United States
a large wattage Zener diode of the appropriate voltage (> 5V) would do the job.
Even though there is a cable and connector and a separate chassis, the threat to the 'table's electronics is, IMO, no different than if the supply was in the base of the turntable. The fact that it's in a different chassis doesn't inherently make it more likely to stop regulating at the proper voltage.
bel
Old 5th October 2018, 11:45 PM   #1163
Alekz91 is offline Alekz91
Originally Posted by Dave Cawley View Post
n10 are 100pF loading capacitors for moving magnet cartridges.
For the start stop you will need to go through this with a scope and the service manual. It would help if you have the SH-10C circuit, but I think you could do it without that.?
Loading capacitors, what purpose do they fill? I have never seen a setup like that before. Can i use any MM cartridge with these?
Start/stop: Okay, thats over my limit. Im decent in following instructions and doing simple soldering but not much above that.
Originally Posted by SAP7 View Post
There’s a bolt in most headshells that lets you rotate them?
But a small spirit level for headshells and adjust until level.
If the headshell won’t adjust you need one that does!
Thanks! That helped. Kind of embarrassing. But never had this issue before!
Old 6th October 2018, 12:13 AM   #1164
ralphfcooke is offline ralphfcooke  United Kingdom
Though it would involve a few more components I'd probably go for a 'crowbar' circuit, along with a fuse, a 5.3V zener should provide sufficient overhead.
Something like this:-
Old 6th October 2018, 03:39 AM   #1165
Algar_emi's Avatar
Yeap, exactly the kind of circuit I was planning to install on the 5V. And BrianL I agree that a separate power supply isn't different from one built in, but the catch is often that you can use the table with an other power supply, and this one can be defective... The crowbar circuit is fail safe, fast, blow the supply fuse and protect the table. It was used a lot into big, expensive HP test equipment power supplies in the 80's. Work like a charm... Anyway once I'll complete the repair on my second SP10, I don't want to have to do it again!
Old 7th October 2018, 05:59 AM   #1166
If these were as common as USB chargers and with as profligate use, then I'd agree that there is protection needed. I wouldn't expect the average SP10ii user to be mixing and matching multiple supplies and turntables -- few of us have more than one of each. If so, one should certainly make sure the supply works before plugging it into the turntable.
I'm quite familiar with what we at HP did with power supplies in the 80s. Generally those SCR crowbars were to protect the instrument from someone who plugged their device into a 220V circuit when the voltage selection switches were set to 120V. That's a much more likely scenario that mixing and matching 'random' SP10's and their supplies in 2018.
bel
Old 1st November 2018, 01:48 PM   #1167
Russellswanborough is offline Russellswanborough
SP10 Mk2 speed problems quick fix
This fixes just about all Technics SP10 Mk2 speed problems. Takes a few minutes.
In the SH-10E power supply:-
On the 5v rail:
1. Replace C411 (100uFd / 16v originally) with any value above 150uFd and 16v that will fit (I use 200uFd 16v) (this is sometimes the only mod you need to make).
2. Solder an additional 1,000uFd / 16v capacitor across C410 (1,000uFd / 16v originally); LEAVE the old cap in place, it's usually OK, just old and tired. Make sure polarity is OK. Only replace if leaking (unlikely).
If it still cogs, then on the 32.5v rail:-
3. Solder an additional 1,000uFd / 80v capacitor across C413 (1,000uFd / 80v originally); LEAVE the old cap in place, it's usually OK, just old and tired. Make sure polarity is OK. Only replace if leaking (unlikely).
99% of the time this works. If it still doesn't, get back to me.
Old 4th November 2018, 05:18 PM   #1168
Lordcloud is offline Lordcloud
I know I'm incredibly late to the party, but does anyone have one of the MK2 heavy platters that they'd like to sell?
Old 27th November 2018, 12:56 PM   #1169
SAP7 is offline SAP7
Need a bit of urgent help.
Recapping my sh10e. As we speak.
Caps 411 and 412 are listed as 100 16. My unit has 100 50v. Same as the 414 and 415.
Should I replace with like or go with what the online list says??
Old 27th November 2018, 01:00 PM   #1170
It really doesn't matter as long as the caps are of higher voltage than the supply they sit across, and are of decent quality. And of course, fit in the required space.
The Incredible Technics SP-10 ThreadHide this!Advertise here!
Technics SP 10 Speed Problems rollinr Analogue Source 29 27th October 2017 10:05 AM
Technics SP-10 Doesn't Spin breadhead Analogue Source 6 27th October 2014 12:09 AM
Cheap oscilloscope for setting up a Technics SP-10 johnm Analogue Source 22 28th June 2011 08:47 PM
Technics SP-10 speed problems Stefanoo Analogue Source 3 17th August 2008 11:05 PM
Technics SP-10 MKII pitch control peterb Analogue Source 6 28th March 2004 02:29 PM
Copyright ©1999-2019 diyAudio
