The Incredible Technics SP-10 Thread
Hi ,
I bought a fantastic condition sp10 mk2 last week,it came with a running spare sp10 which is in poor cosmetic condition. It differs to the good one by having a red LED on the start/stop button and a sticker on the bottom cover has an X after SP10 mk2.
Does anyone have any info on this model please?
I must have seen about 200 SP-10MK2's here in the UK, none had any led in the start/stop.
i decided to take some shots of the pcb's
the first thing i noticed was a resistors been added here.
Hi JP,
Yes you are correct,with the remote jack removed the LED light goes on and off when the start/stop button is pressed but the TT doesn't spin,putting the jack back in and the TT spins. Is this some crude work around to replace something?
No, sounds like a master console lockout or something similar. It may be that the remote jack can still facilitate remote s/s as well, but no way I can tell with out a schematic.
Your connector is unusual and different from the stock one like mine ... even my connector had resistors attached to the back, the cables were connected to a button and the start / stop button.
I can confirm that it was a Matsushita commissioned adaptation and is not a DIY; a turntable similar to mine produced the same year/month and day and with very close serial numbers owned by an Australian (I reside in Europe) had the exact same modification.
I think it was used to turn the strobe light on or off independently of the start/stop button.
had a couple of days free to make a panzerholz plinth for mine,my main turntable is a sony tts-8000 so i was keen to compare.
just finished setting the sp10 up and im impressed. not a huge difference but there is one for sure,i get the cd like comments often made on forums,im also hearing a more detailed focus, again not huge. so far so good. once i get used to it i'll finish the plinth.
That looks pretty sweet Jamie, you have a super mint deck there !
And is that the Phonomac tweaked Audio Technica arm ?
Looks wise Im well into the arm and am curious as to how it sounds ....?
