I just got a pioneer PL112D. It's in great shape but, the lateral weight is missing.
I discovered that its about 6.5 grams .
Does anyone know an easy way to make something that would work?
Keep in mind the I only have access to hand tools and simple power tools like a drill and a Dremel.
BTW, yes I know how to adjust a lateral weight so, can I assume that the weight is not that critical as long as it's in the ball park?
In any event, I read where many just removed the lateral weight....... anyone know about that?\
Perhaps it's just an imaginary tweak?
Update .......
The turntable was actually an e-Bay purchase made in the middle of a sudden sudden urge to get back into vinyl and I did not want to get something expensive.
Upon closer inspection of the pics last night on the e-Bay sight ( and in the Manual) I notice that there were a few other things missing or broken.
Fortunately, it being a holiday in the US yesterday, it was not shipped yet .
So, I the messaged the seller lat last night and he agreed to cancel the sale..
Live and learn.
BTW this was to be my first "S' shaped tome arm on a turntable that had any small semblance of some quality so, the lateral weight is somewhat new to me.
I still shed a little tear when I think of the pristine Thorens TD 160 with a Shure V15 type II that I basically abandoned years ago .......long story.
Anyway, I'm still looking.
Live and learn.
That is your bias weight. I wouldn't use it without it. You can probably find a parts table of the same model and pull one off of that. Check the auction sites.
I think Joe meant the weight that sticks out at the rear of the arm, to one side, that balances the arm axially on S and J shaped arms, not a bias weight.
I'm not sure Joe. What I do know is that it balances the mass of the arm that is offset to one side, if you imagine a line, perpendicular to the line of the vertical pivot bearings, over the top of the arm itself. The arm wand is offset to one side of this line.
The more I look at it, the more I believe you are correct ...... at least to a large degree.
With an "S" shaped tome arm like that, the lateral bearings on the gimbal has unequal load and the lateral weight balances the load.....as you said.
- Analogue Source
- tone arm lateral weight. missing ..........
