Motor for turntable
Motor for turntable
Old 12th August 2016, 07:11 AM   #191
COX77 is offline COX77  France
Meldano, PM sent for controller boards.
Old 12th August 2016, 07:21 AM   #192
meldano is offline meldano  Germany
Reply via PM
Muses Volume Kits avaible
https://www.diyaudio.com/forums/swap...es-volume.html
Old 27th September 2016, 01:34 PM   #193
richrowley is offline richrowley  United Kingdom
Old 10th October 2016, 04:18 PM   #194
New black beatiful boards with little improvements avaible
Old 11th October 2016, 05:01 PM   #195
Highlights:
- Sinus and Cosinus Output
- Output xx-22V (adjustable with pot) with standard transformer and high voltage (115/230) with step up
- High Power Output with LM3886
- Adjustable phase shift between the two output phases
- Adjustable speed up ramp
- Adjustable frequence for two steps
- USB Configuration with PC Application (English or German)
- working hour timer
Old 11th October 2016, 06:09 PM   #196
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Motor for turntable
Don't forget easy assembly, rock solid reliability and utter immunity to mains variation.
Paradise Pre-reg PSU PCBs
Old 12th October 2016, 12:56 PM   #197
ralphfcooke is offline ralphfcooke  United Kingdom
Could these boards be used in conjuntion with more powerful amplifiers/motors by leaving out the LM3886 devices?
I have 30~50W Papst motors that need accurate 3 phase drives.
It's quite straightforward to generate 3 phases from Sine and Cosine signals.
Old 12th October 2016, 01:26 PM   #198
If you build your own amp stage it is possible
Old 12th October 2016, 01:31 PM   #199
PC App...
Old 25th November 2016, 10:47 AM   #200
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Motor for turntable
Anything speaking against using a single phase of the boards feeding into an LM3886, which in turn is driving a step up transformer to which a single phase 230VAC motor is attached? I'm thinking of running a TD 124 with that setup.
Gravity - Making the G since 13.7 billion B.C.
Motor for turntableHide this!Advertise here!
Compact Disc Motor and Turntable - Advices for Replace and Motor Service wanted tiefbassuebertr Digital Source 8 21st September 2018 04:39 PM
Three motor turntable ANALOGIST Analogue Source 37 22nd November 2014 05:58 PM
Turntable Motor davecooper Parts 0 21st October 2010 12:18 PM
Help required for using a FDD motor as a turntable motor. binspaul Analogue Source 5 13th May 2009 03:59 AM
Motor for turntable. Tomek Analogue Source 33 9th October 2003 11:29 PM
Copyright ©1999-2019 diyAudio
