Motor for turntable
Motor for turntable
Old 16th June 2015, 11:39 AM   #161
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Motor for turntable
Meldano's AC psu is very good. By far the best Ac controller I've built yet and I must have built twenty of so over the years.
Paradise Pre-reg PSU PCBs
Old 18th June 2015, 11:22 AM   #162
meldano is offline meldano  Germany
Here a blog in german
krishu.de AC-Motorsteuerung mit uController
Old 18th June 2015, 03:28 PM   #163
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
You have pm
Old 19th June 2015, 03:31 PM   #164
kffern is offline kffern  Australia
Motor for turntable
sq225917,
What voltage transformer did you use?
I can only get 2x25v so wondering if there was any overheating problems.
kffern
Old 19th June 2015, 05:12 PM   #165
I used a pair of dual secondary 18v 30VA traffos.mthe PSU has adjustable voltage, you'll be fine.
Old 20th June 2015, 02:23 PM   #166
Motor for turntable
I'm not sure what you mean by "a pair". Did you use 18v x 2 TX?
Any pictures or diagrams of your build would be of assistance. I'm not sure how well google translate will convert the instructions.
Thanks,
kffern
Old 20th June 2015, 03:10 PM   #167
You can use one transformer with 2x18V secondary or two transformers with 1x18V
Old 20th June 2015, 03:58 PM   #168
Kffern, I was assuming you were referring to stepping up the output voltage, not which mains transformer to use to power it. I built mine exactly as per the instructions from Daniel. 1x 18v / 15va.
https://www.flickr.com/photos/596848...7629553367709/
If you look in my flicker you'll see a version for 20v output and a 110v version.
Old 21st June 2015, 02:40 AM   #169
Motor for turntable
Thanks sq,
I will wait for Daniels instructions before asking any more questions.
The BOM he sent me stated a 2x22v TX for the power supply, which is not available here. I can get 2x18 and 2x25v easily.
kffern
Old 15th August 2015, 09:38 AM   #170
Drewaudio is offline Drewaudio  New Zealand
Drewaudio's Avatar
I've just completed my build based on Meldano's board. I used a transformer with two 25vac windings which proved perfect to drive a Rega 24v motor.
I'm really impressed with Meldano's software design and implementation. My Rega performs better and sounds better than the stock 24vac walwart. Top stuff...
Andrew
Motor for turntableHide this!Advertise here!
Compact Disc Motor and Turntable - Advices for Replace and Motor Service wanted tiefbassuebertr Digital Source 8 21st September 2018 04:39 PM
Three motor turntable ANALOGIST Analogue Source 37 22nd November 2014 05:58 PM
Turntable Motor davecooper Parts 0 21st October 2010 12:18 PM
Help required for using a FDD motor as a turntable motor. binspaul Analogue Source 5 13th May 2009 03:59 AM
Motor for turntable. Tomek Analogue Source 33 9th October 2003 11:29 PM
Copyright ©1999-2019 diyAudio
