Which differences between Mark Levinson's "JC-1" and "JC-1DC"
Old 30th November 2014, 02:30 PM   #11
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
In general you are right, but in case of the JC1DC the showed circuit works very fine without transformer with center tap.
I want still to know the differences between the "JC-1DC" and the "JC-1" head amp module. Still no informations?
Where is the developer of both models?
From the JC-1 module I still haven't the internal circuit.
Old 17th August 2018, 10:50 AM   #12
Originally Posted by tiefbassuebertr View Post
Both versions are for operating without mains power supply - just two secondary D-cells are in use.
What is the difference ?
BTW - the mains supply version uses the additional term "AC"
The difference is the year of release - the suffix "DC" means a newer series (release 1976) than the older series without that suffix (release already 1974) go to
ハイファイ堂メールマガジン
Who know the difference between the gain stage circuits of this both versions ?
The schematic of the JC-1DC (potted version), which I have create some years ago, you will find here:
Mark Levinson JC-1DC_ckt[1].
Maybe there is also a schematic of the JC-1 anywhere. The last both pictures are from a device in not worked condition at left channel - unfortunately also in a potted version. The replace of electrolytic capacitors by new ones don't provide the wanted success.
File Type: jpg JC-1DC PCB solder side ser.-No 350.jpg (178.3 KB, 153 views)
File Type: jpg JC-1DC PCB solder site ser.-No 703.jpg (174.5 KB, 148 views)
Old 18th August 2018, 11:41 PM   #13
kevinkr's Avatar
Why don't you ask John Curl directly? He's a very active member here and might still remember what if anything is different between the two.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 19th August 2018, 01:41 AM   #14
stellavox is offline stellavox  United States
Guys,
As I remember, the DC simply stood for battery power.
Charles
Old 20th August 2018, 11:42 AM   #15
Hans Polak is online now Hans Polak  Netherlands
The circuit below is also a JC design.
Maybe this was the version used in the JC-1.
This one shows 2 transistors plus two emitter resistors, but to lower the noise, JC used 8 transistors with eight emitter resistors in parallel.
Hans
Old 29th August 2018, 09:28 AM   #16
Originally Posted by stellavox View Post
Guys,
Charles
yes, but both versions are battery powered working versions.
Hans
If you are right, the different between "JC-1" and JC-1DC" is large. The input signal is fed in at the base, like iFi iphono2 - go to
iFi Audio Model "micro iPhono2": Creating Schematic - help needed
and not at the emitter like the JC1-DC (go to the attached image).
Old 9th October 2018, 09:43 PM   #17
Default High resolution schematic diagram of JC-1DC, the version with synthetic resin potted
here is my old schematic from JC-1DC created in "CIRCUITMAKER" 15 years ago
File Type: pdf mark_levinson_jc-1-dl_stereo_amplifier_sch.pdf (51.8 KB, 25 views)
Which differences between Mark Levinson's "JC-1" and "JC-1DC"Hide this!Advertise here!
Can someone help with Mark Levinson JC-2? atlantaudiophil Solid State 31 30th July 2018 04:33 AM
Mark Levinson JC-2 problem ( broken Line driver ) ken1967 Solid State 7 8th May 2013 10:17 PM
Copyright ©1999-2019 diyAudio
