Doug Self Elektor phono preamp: SA1085 substitute?
Thread Tools
Old 23rd September 2013, 01:37 AM   #1
tcpip is offline tcpip  India
Default Doug Self Elektor phono preamp: SA1085 substitute?
I am thinking of building the phono preamp from Doug Self's Elektor preamp circuit. I intend to buy the PCB which Elektor sells, use the components in the official parts list (may replace NE5532 with LM4562, maybe even not do that) and make my own power supply and case.
But his MC pre-preamp seems to use SA1085 which are not available any more. Any idea whether they are still being manufactured, and if not, then what can I use as substitutes? I need pin-compatible substitutes, since I want to use the same PCB.
Many thanks in advance.
Old 23rd September 2013, 06:41 PM   #2
Any suggestions?
Old 23rd September 2013, 06:57 PM   #3
Mooly's Avatar
What is an SA1085 ? IC ? or transistor (2SA1085)
Old 24th September 2013, 11:00 AM   #4
Oops... 2SA1085, not SA1085.
Sorry.
Old 24th September 2013, 11:05 AM   #5
I tried looking in digikey; they don't have it. I tried findchips.com, and I was pointed to RS Components; none of the other resellers have it. On RS Components, I found this (screenshot attached). It's not that the transistor is not in stock -- it is a discontinued product.
Old 24th September 2013, 11:15 AM   #6
Mooly's Avatar
OK
Well in many ways its just a generic PNP used in numerous commercial applications, however as Doug will no doubt have chosen it for some preferred characteristics such as noise etc (I'm assuming its in the front end) then perhaps he may be the best to ask on a replacement. Even something as run of the mill as the 2N5401 is probably OK.
Why not ask here and link to this thread,
http://www.diyaudio.com/forums/solid...mp-design.html
Old 24th September 2013, 05:02 PM   #7
Yes, the extreme small-signal stage at the input of the MC pre-preamp
... then perhaps he may be the best to ask on a replacement
I was so hoping he would comment, but he's not said anything.
Actually I discovered an earlier thread, more than a year old now, which had been started with exactly the same requirement as mine, and I'm getting some suggestions there. But Doug Self is silent.
Old 24th September 2013, 05:22 PM   #8
Mooly's Avatar
Try asking the question on the thread I linked to
Old 24th September 2013, 06:46 PM   #9
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
The Elektor article states that 2SA1085 is Mr. Self's second choice; he actually prefers the 2SB737 but these are out of production and difficult to source. The Signal Transfer Company happens to sell the 2SB737, see their "Price List" web page.
Both are TO92 with ECB pinout.
Old 26th September 2013, 12:11 PM   #10
quadtech is offline quadtech  India
Here's an interesting article here comparing a BC560, 2SA1085 and a BF423 - and
some surprises....
Common-mode distortion.
Doug Self Elektor phono preamp: SA1085 substitute?Hide this!Advertise here!
Thread Tools
MAT02, 03 Elektor preamp schematic Samuel Jayaraj Elektor 114 6th August 2020 12:51 PM
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
NE 5532 PreAmplifier from Doug Self, Elektor 2012 Saege Chip Amps 80 2nd March 2018 06:52 PM
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
Elektor ECL86 RIAA Preamp pingfloid Tubes / Valves 20 21st April 2005 03:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
