Mini-Me phono preamp
Old 5th June 2019, 04:45 PM   #121
Boydk is offline Boydk  Denmark
Still agree with you
Except the dac output is reduced to around 15-20mV and then amplified thorugh the 6N16.... Only because I like it´s sound. Bass is tight, treble is "silky" in lack of a better word, and the mid´s are to die for... nothing less
That´s the whole reason I started messin´ with the Mini-Me in the first place... I´m in love with the way 6N16B-V reproduces the whole audio spectrum
Old 5th June 2019, 04:58 PM   #122
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Nice, i did the same with my pcm1794 dac in my shanling cd-t100se player . About 150mv at I/V resistor and then srpp 6n6p tube stage. That i liked more then all the opamps and filtering witch there was origenal.
Old 5th June 2019, 05:05 PM   #123
Avoid opamps at any cost when possible
Old 12th July 2019, 03:10 PM   #124
Jacky01 is offline Jacky01  Germany
Hi Ronny, hi all,
this is my version of the Mini-Me.
It`s a combination of 3 parts:
a smal PCB with the tubes and anode resistors, kathode resistors and R1, R20, R21;
the voltage supply, for each chanal one;
and the RIAA network with the coupling capacitors;
There is one problem:
one chanal has less than 0,3mV hum, but the other one has around 18-20mV!
I changed the tubes from left to right, than I changed the voltage supply from left to right, the hum ist still at the same chanal.
At least I changed the part with the RIAA network and the coupling capacitors from left to right and now the hum is at the other chanal.
So, this part makes the problem. I build an other part but the problem is still there.
May be someone has an idea??
Jacky
Old 12th July 2019, 06:14 PM   #125
Koifarm's Avatar
Connections between the tubestages and riaa network should be as short as possible. Your layout does not have that.
Have you measure humm with shorted input?
Sometimes it works better when the heater supply is floating.
Disconnect ground heatersupply and ground anodesupply and place between the two grounds a 1uf nonpolar capacitor.
Old 12th July 2019, 07:27 PM   #126
thanks for your answer.
Yes input was shorted.
Ok, that`s right. But the connections at both channals have the same size. and the hum of one channal is about a factor 100 of the other.
I will test it.
Jacky
Old 19th July 2019, 11:04 AM   #127
Hi Jacky....
Agree with Koifarm. You really gave yourself quite a challenge, dismantling the different sections of this phonoamp instead of keeping all parts as close together as possible with a sensible layout for ground, supply´s & signal traces.
Let´s hear how it goes
Anyone else assembled this yet?? Pictures and listening impressions would be highly appreciated
Old 20th July 2019, 11:43 PM   #128
Jazid is offline Jazid  United Kingdom
Sorry for no reply, I have got stuck with work/life and a distraction of MC SUT loading into the phono. Have made a board for ultra low impedance carts but now want to incorporate settings for higher impedance carts as well Mini-Me phono preamp
Old 23rd July 2019, 11:52 AM   #129
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
I didn't read the whole thread, so I'm not sure if this yet has been discussed:
As for the schematics in post #1, I would not recommend to omit R1 if you opt for an impedance selector switch. A grid leak resistor is mandatory for any tube! So I'd chose, say, 1M for R1 and recalculate the selectable resistors to match the desired total resistance values.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 23rd July 2019, 08:46 PM   #130
Thanks for the info, appreciated, but rest assured I would never build a circuit without a grid leak!
I am using a zobel in parallel with the 47k load and optimising, and now have a series of capacitors and resistors that give the flexibility to optimise my three SUTs. Measuring their performance and optimisation has been instructive for me, but I have yet to judge them against the real world, ie music...
Mini-Me phono preampHide this!Advertise here!
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
6112 and 6111 Mini-preamp TV7 Tubes / Valves 25 22nd December 2011 10:58 PM
FS: Mini headamp/preamp/buffer boards theAnonymous1 Swap Meet 1 26th November 2008 12:39 AM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Copyright ©1999-2019 diyAudio
