Battery powered phono stage battery type advice
All of you with battery powered Bugles, Boozehounds and other phono stages:
What effect does battery type (Alkaline, NiCad, Nimh, others) have on the sound of your phono stage?
I have a boozehound (2sk170 jfet phono stage) which I run off 16 AA batteries.
I could be imagining things but battery type seems to change the sound. Alkalines sound kind of heavy and forward, Nimh sound more detailed w/more depth, maybe less slam. Cheap dollar store non-alkaline batteries sounded not so good.
Also, the alkalines drift in voltage. I've read that Nimh do not.
Obviously the lower voltage (1.2 vs 1.5V) of the rechargeables may play a role. But what exactly is the ideal battery for something like a phono stage?
Also, when running batteries what effect does a capacitor bank have? Is it unnecessary to have say 5,000uf of capacitance after the batteries? Will it just drain the battery on power on? Is the filtering needed?
I find these have plenty of PRAT factor :cool:
Off the Grid Power
" FIVE-FOOT HIGH Nuclear Submarine Batteries are very conservatively designed to outlast the lifetime of a submarine boat, (35 years). One of the great improvements is the use of calcium in the very thick oxide-lead positive plate. This allows low gassing during charging, which results in only adding water once every two years, and much lower charge loss, due to charge migration during stand-by. We estimate for home use you will get 35 years or better with good care. Each cell is 2.0 volts per cell X 7000 amps = 14,000 watt hours, a 12 volt system = 6 cells X 14,000 watt hours= 84,000 watt hour
You want batteries which have a low ESR and can provide, say, 12hrs of supply without too much voltage reduction; SLAs fill the bill.
My understanding is as follows:
1. Yes, you should have some caps after the batteries. The reason is to provide a low ESR supply at HFs (batteries' ESR increases with frequency).
2. However, you don't need much capacitance - hence it's feasible to use film caps instead of electrolytics (film caps sound better). I use Wima MKS4 - 2 x 22uF, 1 x 1uF, 1 x 0.1uF.
Andy
