Technics SL-1200 DC Power Supply
Thread Tools
Old 10th September 2020, 10:47 PM   #291
more10 is offline more10  Sweden
Tonight I successfully connected an external SMPS with PFC. There is no hum or noise from the Technics.
I believe I will build an external power supply. I dont trust the RS-15-24 any more.
There was a static discharge when I touched the Technics. This should be handled by proper grounding. Should I ground through the power supply or through the riaa?
Mårten
Old 14th November 2020, 05:13 AM   #292
peppennino is online now peppennino  Italy
Galactic Hitchhiker
peppennino's Avatar
So, here we are 😄 First of all, many thanks to 6L6 for the tutorial 👍
I started obviously by removing the internal PSU.
I found a cheap PCB for double pi filter and I used 4x22 ohm 5W ceramic resistors. Quasimodo snubber (European tranny) is placed under the board and 3x3300uF caps used in crcrc.
Lifetime Greenhorn | PASSdiy TV | BA2021
Old 14th November 2020, 05:27 AM   #293
Galactic Hitchhiker
peppennino's Avatar
Some pics...
I used the original on/off switch for strobe.
Old 14th November 2020, 05:35 AM   #294
Galactic Hitchhiker
peppennino's Avatar
Removed bridge and snubber caps, placed new umbilical and soldered switch wires to strobe.
Old 14th November 2020, 05:40 AM   #295
Galactic Hitchhiker
peppennino's Avatar
New cable holder on original bracket and Mike 2 pin connector for the umbilical. Now waiting for a Galaxy 2 units cabinet 😃🖖
Old 14th November 2020, 05:44 AM   #296
Galactic Hitchhiker
peppennino's Avatar
Ps. Yes, I know, blue wire is connected to +, normally it is used for neutral... too late 😆
Old 14th November 2020, 07:02 AM   #297
Galactic Hitchhiker
peppennino's Avatar
Original "E" transformer connected for 230V and the pcb
Old 19th November 2020, 03:28 PM   #298
Galactic Hitchhiker
peppennino's Avatar
Almost completed. It works fine!
Thanks to all!
Old 19th November 2020, 03:59 PM   #299
Galactic Hitchhiker
peppennino's Avatar
Yes!
Old 19th November 2020, 05:50 PM   #300
Galactic Hitchhiker
peppennino's Avatar
Just a question: as I used a metal cabinet, does I have to connect it to the ground? And in that case, how can I avoid the risk of ground loop with the earth? Thanks in advance
Technics SL-1200 DC Power SupplyHide this!Advertise here!
Thread Tools
Technics SL-1200 Speed Issue Loren42 Analogue Source 14 12th August 2010 06:18 AM
Technics Sl 1200 bearing nimbus24 Analogue Source 10 22nd July 2009 11:27 AM
only right sound from my Technics SL-1200 kollisionseb Analogue Source 3 12th February 2009 10:59 AM
Technics SL-P 1200 NoBit Digital Source 0 18th April 2008 11:28 AM
technics SL 1200 MK3D tonearms flip Analogue Source 4 6th September 2007 01:43 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
