Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Thread Tools |
#4201 |
Hello, Mike
I recommend rearranging the upper counterweight at the bottom of the pipe to avoid the trigger effect. I liked your idea of using balls on the front guide and a roller on the back. The result is a very stable structure that is very easy to move. I’m giving this for testing tomorrow. |
#4202 | |
PC, to Chordette GEM DAC or O.L. Aurora 4 with Home built Radial LTA or OL Onyx arm Rega Ania to Graham Slee MC pre, to Prima Luna Prologue 1. Troels Gravesen Fusion BAD with Hypex 151's high level input |
#4203 | |
It will be very interesting to hear how yours works. M
#4204 |
Recent experiments and developments puzzle me, these confirm that i get better tracking and sound with a lighter counterweight higher and further from the pivot than with heavier, lower and closer, how can that be?
I know the construction needs refinement, but i had to banish bolt and nut counterweights to get rid of the bass grumble caused by their vibration.....amazing, but true. Any ideas also for a nice counterweight that doesn't need a lathe? Those attentive to my progress will se lots of stiffening, damping etc which will culminate soon in a new parallelogram. If that results in an even better sound i will be delighted and amazed
#4205 |
Mike,
In my first tonearms, the counterweights were placed in tubes and everything was fine, but when I decided to change the design of the counterweight and raised the lower counterweight relative to its axis of rotation, and cut off the upper one completely, it created a problem with downforce. This showed up on the warped records, the tonearm began to take off and lose contact. Then I began to measure the downforce depending on the height and found that with increasing height, the downforce decreases and after passing the dead center, it just took off. I was shocked, the downforce used to increase with increasing lift. In the end, I turned the parallelogram over, the counterweight dropped below the axis of rotation and everything was fine. In post 4091 I can see a roller. I also started with the cart rolling on 4 balls of increased diameter of 7 mm, but it is almost impossible to achieve good contact of all 4 balls. One plane can be drawn only through 3 points of support, through 4 points an infinite number can be drawn. On 3 balls, the fulcrum also shifts, and if we put a roller on the back, which stands stable, then we get an excellent 3-point support. The cart design is lighter and the larger diameter balls roll well on anodized corners. The photo shows all this. |
#4206 |
#4207 | |||
Has this one played music yet? - enjoyable to see what is going on in this field, thanks M
#4208 |
measures as usual
corkScrew RTA - given the great interest on this arm #4150, (1 post, thanks Mike) almost equal to that for Lil Casey prism (0 post), I was a bit lazier than before, making instead some mods and tuning for the corkscrews mechanism, and listened to it for a long time. But let's get to the measures, starting with the stiction ones with the Niffy style inverted pendulum. (see attachment) The horizontal stiction is really interesting, given the considerable weight of this cart (39 gr, cartridge included), = 1,152 mN very close to the 1mN threshold. The measurement of the vertical one looks acceptable, = 2.44 mN: however, it should be noted that since the cartridge is under the rail itself, I had to use a small lever to do the measurement and this makes it less reliable. Perhaps the true data is a little better. My sine bar measurements of the μ coefficient of friction (friction and stiction) confirm +/- the results of the other. (see attachment) - Measuring both the cart complete with corkscrew (2/3 of the weight!) and naked one (9.5 gr) the results are practically overlapping, almost no difference. B type corkScrew cart - Total weight = 39 gr friction - runs with a tilt of a 0,20 height / 300mm rail. angle = 0°2'17" = 0,038 decimal --- μ=0.00066 stiction - starts with a tilt of a 0,45 height / 300mm rail. angle = 0°5'10" = 0,086 decimal --- μ=0.0015 bare horizontal cart - Total weight = 9,5 gr friction - runs with a tilt of a 0,18 height / 300mm rail. angle = 0°2'2" = 0,034 decimal --- μ=0.0006 stiction - starts with a tilt of a 0,40 height / 300mm rail. angle = 0°4'34" = 0,076 decimal --- μ=0.0013 As said in the presentation, the critical point of this arm is the relationship between the flexibility of the hinge and the two arms with CWs. The holder itself causes noticeable changes even with minimal variations in width and stiffness. I made 3 conceptually different corkscrews, changing several widths of the holder and stiffness of the hinge. Here are the data of the one used for videos. VTF variations measuring device (see attachment) warp 0.25mm = 0 var. - 0.5mm warp = 0 var. - warp 0.75mm = 0 var. - warp 1mm = 0.1 var. - warp 1,5mm = 0,4 var. - warp 2mm = 1.1 var. - warp 2,5mm = 1,8 var. You may note the hinge's "elbow - lever" effect, good on average warps, horrible with horrible ones. (but no worries, look at the video) I enclose the videos of my crash test (eccentricity 1,5 mm - warp 2 mm - warp 3 mm - eccentricity + warp). Not so bad even on severe warps, compared to others. Thanks for your attention: I spare you my impressions on sound and other irrelevant details, as usual. carlo PS: due measuring difficulties with such minimal frictions all data are an average of repeated tests |
#4209 |
Great information Carlo, not surprising perhaps with your care to the measurement techniques ( I think your measurement instruments are better built than my arm!), beautiful build as we always see in your projects and an elegant and simple principle that gives close to the perfect environment for the cartridge to do its work without any undue loads to work against.
Measurements to aspire to! You mention LC prism which i believe is the arm you listen with yourself at home, and although you are not describing the sound on CS, will you now listen at home with CS instead? - Anything you hear that tells you this principle is allowing the cartridge an easier life? Mike
#4210 |
Now we are almost back in lock down here, there will be attention to some experiments.
Here attached are some pictures of my latest modifications. The cart remains the same with low friction non recirculation ceramic balls but the warp accomodation has a spread frame to increase stiffness, allow the cartridge to be higher etc, it's still using Mylar hinges. Reduced bass resonance and surface noise with an appealing detail, tuneful bass etc. Now this one is working well i hope to build a tidy version Any one else got some interesting news? Mike
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Linear tracking tonearm vs. Pivoting tonearm | Don Nebel | Analogue Source | 5 | 31st May 2015 04:55 AM |
Another DIY Tonearm | johnmarkp | Analogue Source | 0 | 22nd April 2008 12:07 AM |
my DIY Turntables and DIY tonearm | Roger Waters | Analogue Source | 57 | 22nd January 2008 07:05 PM |
Magnetic suspension linear-tracking tonearm? | Shaun | Analogue Source | 5 | 4th June 2003 11:21 PM |
New To Site? | Need Help? |
